Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
electrical problem? Please Help
Old Mar 22, 2004 | 07:57 AM
golfer9911's Avatar
golfer9911
Default electrical problem? Please Help
I have a 2002 dodge ram 1500 4X4. I installed an airram CAI a while ago. I had read that I should have reset the pcm after I installed it so I decided to try resetting it to see if it made any difference. I did this buy disconnecting the negative battery terminal and turning the key to the start position for 15 seconds. Then I removed the key and reconnected the negative terminal.
The problem I am having now is that whenever I start the truck the headlights and brakelights come on and the wipers and turn signals do not work, also I cannot brighten or dim the headlights. Does anyone have any ideas what may be causing this.
