Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
HELP!!!!!!! PLEASE!!
Old Aug 30, 2005 | 12:52 AM
moriar's Avatar
moriar
Default HELP!!!!!!! PLEASE!!
Hey guys, im havin big time problems with my truck and wondering if you guys can help.
Alright i have 94 Dodge Ram 1500 4x2 5.9ltr truck.
and here's the problem..
Well i changed the oil on my truck, then i went to start the truck and oil pressure gauge was readin a bit low (25psi) at idle, and i was like hmmm??? seemed really low, then i look
at the sensor and it looked a bit rough so i replaced it, well i read evn lower... 20 psi, so i said **** it, and replaced the oil pump, oil pick up, oil pickup screen. and started it up
and it read 40psi at idle, and i was like "YES" ive got it fixed . but then i drive it 10 feet and the pressure drops to 15 psi... then the oil light itself lights up, and then my temp
gauge spikes to 210 degrees. I then looked to make sure everything was nice in tight, and it was.
Oil im using 10w-30 Castrol GTX
Filter im using Dodge OE Filter.
please help quick!! I need this truck bad next week to tow my race car!
Old Aug 30, 2005 | 01:16 AM
DevilsReject's Avatar
DevilsReject
Noob Assassin
Default RE: HELP!!!!!!! PLEASE!!
Take it to a dealer and have it put on a machine...spend the $50 for a diagnostic...things like that can be tricky....
Old Aug 30, 2005 | 01:20 AM
RamRough's Avatar
RamRough
did you see any contaminates in the pan o rin the filters? Maybe chaeck the oil for contaminate slike fuel or antifreeze?
Old Aug 30, 2005 | 01:58 AM
moriar's Avatar
moriar
i thought it might have been a clogged filter.. it wasnt, ive gone thru 2 oil changes, and it still didnt work
i cleaned the entire pan, all that was there was a tiny peice of sludge and that was all, the oil screen had a couple tears in the mesh. but it didnt look bad.
Old Aug 30, 2005 | 10:41 AM
Drew's Avatar
Drew
I would try a mechanical pressure guage to see if the electric one is working properly.
Old Sep 6, 2005 | 06:47 PM
MGDMike's Avatar
MGDMike
Any word yet on what caused this problem?
