Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Will this fit under the back Seat.
Old Sep 10, 2005 | 11:14 PM
WhoDatIz's Avatar
WhoDatIz
Default Will this fit under the back Seat.
Will 2 10' Kicker Solo X Subwoofers fit under the back seat?
Old Sep 10, 2005 | 11:22 PM
DevilsReject's Avatar
DevilsReject
Noob Assassin
Default RE: Will this fit under the back Seat.
No, they will not.
The mounting depth on those particular speakers are almost 9 inches.....not to mention the box you would need to surround it. I'm sure if you modifed the rear seats you might get it to fit....
You need to look for something around 5 1/2 - 6 in mounting depth.....there just isnt enough room under the rear seat....
Old Sep 10, 2005 | 11:25 PM
DevilsReject
Noob Assassin
You could try the Solobaric L7 10's.......6 3/8 mounting depth.
There are lots of pre-fabricated subwoofer boxes that will fit directly under the rear seat. My suggestion would be to decide on a box and then find speakers that fit the box both in mounting depth and air space needed....
Old Sep 11, 2005 | 12:52 AM
WhoDatIz's Avatar
WhoDatIz
since those wont give me some suggestions
Old Sep 11, 2005 | 03:00 AM
DevilsReject
Noob Assassin
Well, for starters I would decide on whether you want to build your sub box or use a fiberglass/custom form box. Also, you really need to decide how much of a system you want. Do you just want a lil bump or do you want a ton of bump. Also, are you using an aftermarket headunit (Cd player) or are you using the factory one?
Give me some idea of what you have and what you are trying to do and I can probably help. There are several others in the audio section and Ram section who could also help....
Old Sep 11, 2005 | 03:04 PM
WhoDatIz's Avatar
WhoDatIz
well i want a ton of bump im going to get a aftermarket headunit, i dont know what type of sub box i want but i might go with fiberglass for the box.
Old Sep 11, 2005 | 05:27 PM
Fourtwenty's Avatar
Fourtwenty
I have 2 10" Alpine subs and they fit perfectly. Hope that helps. Check https://dodgeforum.com/m_287975/tm.htm for pics since I just posted them there.
Old Sep 12, 2005 | 03:49 AM
DevilsReject
Noob Assassin
For a ton of bump, definitely want a fiberglass box....and two amps....I'd also look into dyno-matting the entire rear or the truck...but thats expensive...
I suggest the dynomat just because it will help reduce the nasty rattle noise....other then that....some decent subs
Old Sep 13, 2005 | 01:05 AM
ross944's Avatar
ross944
your going to want to lift the rear seat either way. my mtx 8000's have 6" depth and with the box i got it still hit the bottom of the seat. just went to home depot used some copper piping as a spacer and got longer bolts for the seats. took 15mins and less than $5, well worth it.
Old Nov 16, 2006 | 09:04 PM
sdodge's Avatar
sdodge
Default rear seat spacer?
Hey, I have a '02 quad and I notice that you said that you used spacers. Lifting the seat didn't mess up the back part of the seat? I heard it would come loose. Please email back at dhughes77365@yahoo.com I like my power mod also, thanks!
