Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
hood insulation
Old Mar 29, 2004 | 01:42 PM
rootersbar's Avatar
rootersbar
Default hood insulation
I have a 99 full size ram that I love! I have a problem though, the hood insulation is drooping and laying on my coolant hose which is burning some of the insulation to the hose. The insulation is ripped at the connection points so I really cant reattach it. Would there be a problem if I removed the insulation all together? What is it even there for?
Thanks
Old Mar 29, 2004 | 02:42 PM
stupidface's Avatar
stupidface
Default RE: hood insulation
i think its there to muffle some of the engine noise, if u really want, ur local autoparts store should have a replacemnt type heat sheild mat
Old Mar 29, 2004 | 02:46 PM
rootersbar's Avatar
rootersbar
thanks, I appreciate your response. Do you think there would be any problems with just ripping it out? I dont mind the noise
Old Mar 29, 2004 | 05:59 PM
stupidface's Avatar
stupidface
prolly not, i have old skool cars that should have it, they have it taken out to pimp the motor with mirrors or chome under the hood,, i see no prob's senior
Old Mar 29, 2004 | 06:02 PM
Aftrshck's Avatar
Aftrshck
the insulation mat also keeps the heat off of the hood itself. By removing it, the heat-intime- will discolor the hood and leave odd looking heat marks on the hood....my recommendation would be to keep it on and manage a way to either replace it or patch it as needed...
Old Mar 29, 2004 | 06:06 PM
dodgefreak's Avatar
dodgefreak
ORIGINAL: Aftrshck
Its also supposed to keep flames under the hood incase of a fire.
Old Mar 29, 2004 | 06:08 PM
Aftrshck's Avatar
Aftrshck
ORIGINAL: dodgefreak
well that too...but I just figured I would mention the cosmetic reasons...that is what will make most people see the truthful part of why it is there...
Old Mar 29, 2004 | 06:55 PM
Connect's Avatar
Connect
Yeah, the heat can discolor/warp the hood over long periods of time, i suggest you get aftermarket insulation that hugs the hood really tightly. Probably at your local auto parts store.
Old Mar 29, 2004 | 08:12 PM
rootersbar's Avatar
rootersbar
thank you all so much for the advice, thank you also for taking the time to reply to me, I cant tell you how much I appreciate it. This is an awesome forum, hope I can help someone sometime soon!
Chad
Old Mar 29, 2004 | 08:32 PM
Aftrshck's Avatar
Aftrshck
you are very welcome...I am just glad I could help...
