Dodge RamThe full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Does anyone know how to change the left side of my 2004 5.7 Quad Ram? The right side headlight is not a problem, but the fuse box is in the top of the left side headlight, do I have to remove the fuse box to change the bulb? Any suggestions?
Thanks
Hi Slaywick, Can you reach the headlight assembly from the inside, near of the fuse box, or you have to go under the truck, and remove it from there? thanks
As a certified dodge tech I can tell you it will make life much easier if you do just take out the headlight assembly to change that bulb
yeah the right one was easier than the left when i changed my headlights to the sylvanias. between the top of the bumper and bottom of the HL assembly is where your socket should fit. just pull the whole thing out. goodluck
its a little more safer to open, pull the whole assembly out instead of trying to snake ur arm through, i snaked in a set of bright high blue headlights and my pinky barely grazed the one light and it busted the second i turned it on the headlight, ruined the pasenger light assembly, but luckly i went in and dissasembled the headlight assembly to clear corner my headlights and now they are pimped out chrome, sorry for the long post
