Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Infinity factory amp?
Old Apr 3, 2004 | 01:10 AM
DSR_TIM's Avatar
DSR_TIM
Default Infinity factory amp?
I installed a kenwood kvt-715dvd today and can not get sound, so I need to know where the factory amp is located so I can bypass it and also if anyone else has had this problem. it is a 04 quad cab
Old Apr 3, 2004 | 01:05 PM
stupidface's Avatar
stupidface
Default RE: Infinity factory amp?
if ur using the metra wiring harness or any other wiring harness, there is a blue wire coming from the store bought harness not the headunits remote but the wiring harness its a antena turn on the wire harness its blue splice into ur red 12+ign wire, on the same harness and voila it should be done,note these are the wires from ur aftermarket wire adapter harness not the aftr market headunit. or run the headunits remote(blue wire that says amp on) wire in to the blue wire antenaa turn on wire harness purchased for the install, both ways the blue wire is on the adapter kit(harness) u bought (if so),u could eether use the truck 12volt igntion wire to the radio or us the new radio remote wire(blue)to ease the install
Old Apr 4, 2004 | 04:47 AM
Parts/Service's Avatar
Parts/Service
The factory amp on Infinity unit is built into the Door speakers.
Old Apr 4, 2004 | 07:34 PM
meurich's Avatar
meurich
I have seen several posts that say the factory amp in the new body style (2002+) is behind the glove compartment. But, I guess I can't argue with a parts in service manager. Although I will argue with a Ford drvier any day. :&gt
Old Apr 4, 2004 | 07:53 PM
mazz's Avatar
mazz
Older Infinity systems did have the amps on each speaker. However, on the new body-style Rams, the amp is behind the glove compartment.
Old Apr 4, 2004 | 11:29 PM
356MAGNUM's Avatar
356MAGNUM
I have an '02 and put on a mono amp for a box behind the seat. I had to use a line level adapter to get from speaker to line level. First I tried behind the player itself vel low level. Then I tapped off of the rear speaker wire on the back wall. And this worked. I would have to go with the amp is behind the glove box.
Old Apr 4, 2004 | 11:33 PM
356MAGNUM's Avatar
356MAGNUM
Default From the '03 Ram Maint. CD
AMPLIFIER
DESCRIPTION
The optional Infinity premium speaker system
includes a separate Infinity audio power amplifier.
The amplifier is a six channel unit and is rated at
240 total output watts. The amplifier is located
OPERATION
The power amplifier electronically increases the
frequency response of the normal audio signal output
from the radio amplifier in order to improve the
acoustic performance of the speakers. On vehicles
equipped with an amplifier, the amplifier section of
the radio becomes a pre-amplifier.
The amplifier receives audio signal inputs for
speaker channels from the radio, then sends amplified
audio outputs through six separate channels
with dedicated feed and return circuits to the individual
speakers.
