Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Ram SPORT headlight conversion issues
Old Apr 4, 2004 | 04:12 AM
5SPDSLT's Avatar
5SPDSLT
Default Ram SPORT headlight conversion issues
OK so I have been installing a set of aftermarket dual SPORT headlights into my truck. I wired the system a few weeks ago but chickened out for the finall tap in and headlight install......until this afternoon.
A little background first. I am using the high and low beams on all four lights. The original SPORT models only used the outer low beams (9007 bulbs) and all four high beams (9004 and the outer 9007 bulbs). I wanted to use all four bulbs on the lows and highs. I have set up the sysem using the existing wires from the driver headlights to activate four relays to light the bulbs. I have also installed a separate fuse panel the system.
The wiring worked fine and I will write a tech article when I am done (I have pictures and have created a wiring diagram for all to see). The problem is that the corner lights are different on the SPORT headlights in comparison to the standard Ram. I ended up installing the stock fixtures for now but now a have to order the proper corner lights to fit.
This is not a big deal.......I just wanted to cry to someone. I have checked the place that I got the SPORT headlights from (WWW.PROCARPARTS.COM) and they have the diamond clear corners to match. So thats all........
Eric
Old Apr 4, 2004 | 10:36 AM
Ratchet's Avatar
Ratchet
Default RE: Ram SPORT headlight conversion issues
Do you have any pics with the new headlights installed? I've thought of putting the sport headlights in as well, but I'd kind of like to see what they look like.
Old Apr 4, 2004 | 04:03 PM
Deviousin10tions's Avatar
Deviousin10tions
What is the difference in lights?
Old Apr 4, 2004 | 06:47 PM
5SPDSLT's Avatar
5SPDSLT
I wasn't able to install the SPORT headligts because the corner lights did not fit them. I will have pictures of them next week when the proper lights get here. I did dry fit them and they look great.
The difference in the lights are the way the corner lights slide into the headlight frame. It is different from one to the other. I will take pictures of the difference when I get the new corners in.
I was wondering why all of the aftermarket corner lights would say that they were for the 'NON-SPORT' models. Now I know. So I made the mistake for all of you guys. Now you owe me one.
Eric
Old Apr 4, 2004 | 07:10 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
That's one less mistake you'll make in the future....[sm=smiley4.gif]
