Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
no headlight in 1998 2500 ram
Old Jul 6, 2014 | 12:29 AM
redbullmorton's Avatar
redbullmorton
Default no headlight in 1998 2500 ram
I have a 1998 2500 Ram Canadian built truck. The fuse for the DRL blew so I replaced it. Blew again. Saw smoke by the relay under the master cylinder so I pulled fuse. Couldn't find a short so I replaced fuse again and now only have headlights if I hold the dimmer switch back. Neither low beam or high beam work unless you hold dimmer switch back manually.
Could this be a bad DLR relay or dimmer switch or something else?
Old Jul 6, 2014 | 12:50 AM
archemedes74's Avatar
archemedes74
did you see what smoked? Might have been a wire burned in 2, might have been the relay. There had to be something wrong to pop the fuse, something drawing a ton of current. See where the power stops (I'd start at the relay since that's where you had smoke) you'll want a wiring diagram as well
