Draining water from filter hou
Can anybody tell me how to check the filter housing for water and how to drain it when needed? If this has already been covered, please forgive the redundancy, and let me know where to find the information. Thank you. The specs on my truck are in my signature/
You shouldn't be getting water in there whatsoever... Take of the screws and clamps remove the housing, and take it off the truck and drain it. It's quick and easy...
~Amanda
~Amanda
THERE'S A LEVER HANDLE ON THE SIDE OF THE HOUSING THAT DRAINS LIQUID FROM THE BOTTOM. THE CONDENSATION IN THE FUEL TANK WILL COLLECT IN THE FILTER AND CAN GET DRAINED THIS WAY. YOU COULD USE A DIESEL ADDITIVE THAT MIXES WITH THE MOISTURE AND WILL BURN. THE FILTER SHOULD BE CHANGED EVERY YEAR ANYWAY.
