gas mileage improvements
I've got a new Dodge Ram Quad Cab 4x4 with the 5.2L 318 engine. Its got 120,000 miles and currently only getting 11.5 to 12 MPG and that is mostly highway. It has a K&N filter, and i just replaced cap, rotor, plugs, wires, and oxygen sensors. What can I do to improve this at all? I didn't buy the truck expecting great mileage, but was expecting a little better than this especially on the highway.
kevin
kevin
Unfortunatley I don't think that you are that far off in gas mileage. It has little miles on it and is a 4x4. You don't know if the previous owner may have changed the gears do you? How does she run? What type of Rpms are you running at highway speed say 65-75 mph? Oil change would help some specially if you change to senthetic. You mentioned replacing the O2 sensors you might check the Cat also. Just some questions and observations.
ORIGINAL: kevro7
kevin
kevin
That mileage and engine combo is very similar to my Ram.
On my 1994 Ram, I increased my mileage by + 3mpg by doing the following:
(1) I used 2 cans of Chrysler Combustion Chamber Cleaner (in two treatments). I sprayed the stuff into the throttle body with the engine running.
(2) New spark plugs, wires, and dist. cap.
(3) Replaced the O2 sensor (94 only has one)
(4) I poured one bottle of Amsoil engine flush in the cranckase, with the old oil and idled the truck for 20 minutes.
(5) I drained the oil / flush, and replaced it with Amsoil SAE 10w-30 synthetic oil.
(6) I replaced my petroleum gear lube and changed both axles to Amsoil 75w-90 synthetic.
(7) I changed to a 180 t-stat.
This is what I did and the results were dramatic.
In my Dakota, the synthetic oil and gear lube were good for 1.5 to 2 mpg.
Bill,
Thanks guys/gals.......
a little more about it. i haven't changed the case oil or axile oil yet, but is on my to do list. I have however changed engine oil to synthetic and added "Restore" engine treatment and have changed tranmission filter and fluid. I've run a bottle of fuel injection cleaner. Truck runs pretty well. It has an aftermarket exhaust on it, but i don't know what it is. Its kind of old so i'm going to replace it this summer to a dynomax ultraflo. I was thinking about replacing the cat while i'm there. Should i stick with an OEM cat or maybe a High Flow cat? As for gears, i couldn't tell you, don't know what its got but on the highway running 70-75 mph, it reads an rpm of around 2200-2400. What is the stock thermostat in these trucks?
also a couple days ago, i was driving.. went in reverse for a about 50 ft. and then when i went into drive and started to take off, it sputtered for a little while kind of like the old carbureated engines would when they would load up. thats the only time it has ever done that. ?????
kevin
kevin
