Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
02-03 9 1/4 Rear Axle with Tow package bulletin
Old May 5, 2004 | 12:47 AM
356MAGNUM's Avatar
356MAGNUM
Default 02-03 9 1/4 Rear Axle with Tow package bulletin
From http://www.dodgeram.info
Date: July 1, 2002
Models: 2002-2003 (DR) Ram Truck
NOTE: THIS BULLETIN APPLIES 2002-2003 (DR) RAM TRUCKS EQUIPPED WITH THE 9 1/4" REAR AXLE AND TRAILER TOW PACKAGE (AS ORDERED OR DEALER INSTALLED).
Discussion:
It is critical to optimum performance in trailer towing conditions that when service is being performed on the 9 1/4"' rear axle on 2002-2003 (DR) Ram Trucks equipped as noted above, the axle must be refilled with Mopar 75W-140 Synthetic Gear and Axle Lubricant (PN 04874469).
NOTE: 148ML (5 OZ) OF MOPAR FRICTION MODIFIER (PN 04318060AB) MUST ALSO BE ADDED TO VEHICLES EQUIPPED WITH THE TRAC-LOK STYLE REAR AXLE.
Policy: Information Only
Old May 5, 2004 | 12:55 AM
moparturd's Avatar
moparturd
Default RE: 02-03 9 1/4 Rear Axle with Tow package bulletin
Yeah. They like that axle fluid too. Mobil 1 or another synthetic lube of the same weight will work fine, but the friction modifier is a must have from mopar. I have used the modifier from the parts store and the rear made a bunch of noise.
