Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
How many inches of lift will i need to run 35's on my 95 ram?
Old May 5, 2004 | 11:56 PM
showen04's Avatar
showen04
Default How many inches of lift will i need to run 35's on my 95 ram?
Like i said does anyone know how many inches of lift total i will need to run 35 inch tires on my 95 4x4 longbed ram. it is regular cab. Also should i just get a body lift or suspension. i will do a little offroading but nothing extremely severe or anything, just mostly in fields. i don't know if its worth the money to get a suspension lift in my situation. Is anyone else running 35s on their Ram? How many inches of lift do you have and is it body or suspension. How difficult is it to install each? Sorry for all the questions but if anyone can help me out thatd be great.
Old May 6, 2004 | 02:31 AM
fourbyfanatic's Avatar
fourbyfanatic
Default RE: How many inches of lift will i need to run 35's on my 95 ram?
You can get away with 4 inches of lift for 35's. You might rub a little at full turn on the steering wheel and full suspension compression. 4" lift is pretty reasonable price wise. 6" is the most common and will give you no rubbing. As for body lifts im personally against them. they can be unsafe if you really use your 4 by hard and they are just plain ugly, all that frame showing. Ive seen a truck body sheer off the frame under heavy use and to tall of a body lift but it can still happen . Plus a suspension lift will give you more durable components to handle the extra weight of those big heavy 35's whereas a body lift leaves the suspension parts stock.
Old May 6, 2004 | 10:52 AM
cubfan23's Avatar
cubfan23
I have a 5.5" "Superlift" suspension lift kit on my 2500 4x4. It isn't ugly and the frame doesn't show since the suspension is lifted, not the frame. I also have 35" BF Goodrich Mud-Terrain tires on it and I don't have any rubbing at all, no matter how far you turn the steering wheel.
[IMG]local://upfiles/3352/Sq470326215.jpg[/IMG]
Old May 6, 2004 | 10:55 AM
moparturd's Avatar
moparturd
Man, I have to say that that truck looks good.[sm=smiley20.gif]
Old May 6, 2004 | 11:34 AM
Vader's Avatar
Vader
whats your gear ratio ??
Old May 6, 2004 | 01:23 PM
cubfan23's Avatar
cubfan23
Thanks!!! [sm=smiley4.gif]
Old May 6, 2004 | 03:44 PM
badblackram's Avatar
badblackram
I put a 2" spacer on the fron of my 99 3/4 ton cummins and I am running 315/75/16 (35/11.50/16) no problems other than fuel milage
Old May 6, 2004 | 03:56 PM
slvrmagnum's Avatar
slvrmagnum
I had 11 inches of lift on my '01 2wd and I was able to fit 37" and 38" tires on it.
Old May 6, 2004 | 06:15 PM
billyd12's Avatar
billyd12
I'm gonna lift mine w/ +4 rear leaf springs, and +2 shackles...
+2inch spacer in front w/ +3or +4 coil springs...
i plan on running 35 or 36 Mickey T's... baja radial.
Old May 6, 2004 | 10:50 PM
fourbyfanatic
Cubfan, real good lookin truck
