Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
CAI??????
Old May 18, 2004 | 12:52 AM
shott8283's Avatar
shott8283
Default CAI??????
thinking about a CAI on my 01 Ram Sport 5.9L 360. any suggestions on what works well? and for the money which is best? also i had recently replaces the stock filter and put a K&N but had a hell of a time getting it to seat well... still using the stock airbox.. this common? worried about sucking crap into my motor....pray to the heavens havnt happend already....and the sealing grease you are saposed to use to put it in...is it possible to apply TOO much? overkill? really kinda worried i sucked something in my motor.....thanks
Old May 18, 2004 | 02:35 PM
sgbofav's Avatar
sgbofav
Default RE: CAI??????
ORIGINAL: shott8283
You had the same "sealing edge" problem I had.
If you think your engine may have injested some sand or dirt because of the poor seal, just change your oil. This will remove any silicone or "sand" that may have entered your oil, and will increase iron wear if left iin the crankcase. That is all you need to do.
If you want to be creative, purchase an "air-hat", coupling, and S&B air filter from Dodgeforum sponsor 360airintakez . This is what I did and I built my Ram's intake for $125.00 .
Here is a link to the Airhat: http://www.360airintakez.com/cgi-bin...ssories_airhat
Or you can buy one already made: http://www.360airintakez.com/cgi-bin...8:Dodge_Ram_52
I have used both and yes, there is a bigger performance improvement with the intake instead of the "drop-in" filter. The stock airhat on the 5.2/5.9 Rams is restrictive. Removing it and replacing it with an aftermarket one will free up more power.
Bill,
Old May 18, 2004 | 02:49 PM
slvrmagnum's Avatar
slvrmagnum
I have an air intake off of my 2001 5.9L that I am selling for $30 plus shipping. It has a metal, not plastic tophat. Go to thread below.
https://dodgeforum.com/tm.asp?m=3735...=1&key=&#37777
Old May 18, 2004 | 08:06 PM
shott8283's Avatar
shott8283
who makes that intake? and does it provide the power im also looking for? also does a K&N hook up to the end?
Old May 18, 2004 | 08:51 PM
slvrmagnum's Avatar
slvrmagnum
It is made by ProCarParts and yes you can get a K&N and put it on the end, just get the K&N with the correct cone inlet.
