Shift Kits?
RE: Shift Kits?
You mean 46RE trans, we haven't used the RH line since about 97 and all trannies have been 4 speeds since about 90. Contact you're local Mopar performance dealer, there is a shift kit available from Mopar that will do just what you want.
RE: Shift Kits?
http://www.kdsperformance.com/tranhigpersh21.html
this site might give you an idea on what your looking for
RE: Shift Kits?
I put one in my 98 Ram 2500 with the 46RE as well as 2 other friends trucks with 46RE's. The details as well as the Transgo instructions can be found on my website http://www.geocities.com/robertballa...5/Rampage.html
Hope this helps,
Bob
Hope this helps,
Bob
RE: Shift Kits?
puttin a shift kit actually will extend the life of your tranny. but it will be hard on the truck. if u have bad u joints they will show up, or a rear end goin bad, or bad tranny mounts, they will start to show.
a shift kit jus allows more pressure to the clutch assemblies, which means its LESS likely to slip, extendin the life of the clutch packs.
