Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
tranny prob can you help???
Old Mar 9, 2006 | 07:44 PM
mydodge2's Avatar
mydodge2
Default tranny prob can you help???
ok when i driven normal itwill shift two 2gear fine but it hesatates or hold own its in 2 and wont shift to drive normal i hafta let off the gas for it two shift or it will stay in till the rev limiter kicks in,and if it drops from drive two second it acts like its sliping anyone have any ideas???is the tranny shot or is it fixable????? its in a 99 ram 2500 v10?
Old Mar 10, 2006 | 12:28 PM
40intrepid's Avatar
40intrepid
Default RE: tranny prob can you help???
Sounds like what mine started doing two weeks ago, Sunday it finally quit, no 2 to 3 shift.
Bottom line: $1715 to rebuild the trans, new solenoid trans governer, transduce pressure sensor, seal package, torque converter, filter and valve body, and ATF-4 fluid at the Dodge store.
Also had the power steering flushed while it was there.
This was at 55,000 miles.
This was for an 01 1500 2wd 318 truck w/4speed auto.
Sorry,sound like heap big bill coming youre way.[]
Old Mar 10, 2006 | 03:56 PM
RamminGawga's Avatar
RamminGawga
Mostlikely your governor solenoid and/or transducer is out. A seasoned transmission tech with the proper diagnostic equipment should be able to determin if these parts are at fault. I would have both replaced at the same time. These parts have a very high failure rate. Labour to replace them should be around 2-4 hours plus ATF. Transmission stays in vehicle. . Good luck.
Old Jul 14, 2006 | 03:03 PM
txtech1997's Avatar
txtech1997
For a possibly cheaper solution, try having your transmission completely drained and then put in a good synthetic ATF and new filter. See how that goes.
So this doesn't seem like an advertisement, shoot me an email and I can tell you who I recommend.
Charles
charles_holley@msn.com
