Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
3.55 vs. 3.92
Old Nov 10, 2003 | 05:27 PM
Ram Off Road's Avatar
Ram Off Road
Default 3.55 vs. 3.92
I have a quick question.</P>
Is there any noticable difference between the 3.55 and the 3.92 gearing in the Ram when you are not towing? I currently do not tow or haul too much but I will occasionally hook on to a trailer or haul a load of mulch or gravel once in a while. I now own a off-road and have 4.10 gears. I am thinking of buying a new Hemi and just wanted to know if I should get the 3.55 or the 3.92.</P>
Thanks for the help.</P>
Old Nov 11, 2003 | 04:06 AM
IrvineDodgeGuy's Avatar
IrvineDodgeGuy
3.92 gears will accelerate quicker. if the ram has the 20" wheels it will come with the 3.92 gears and anti-spin diff.</P>
Old Nov 11, 2003 | 11:15 AM
Ram Off Road
Thanks for the info. </P>
Do you know if there is a big gas milage difference between the 3.55 and the 3.92?</P>
Old Nov 11, 2003 | 11:30 AM
Dodgegirl19's Avatar
Dodgegirl19
Lady Administrator
I have the 3.55 in my 94... I was under the impression the 3.92 is more of a 'dog' since it's the towing package...? (It's not a dog... it's awesome.) I just thought the 3.55 was faster...? Hehehe! Am I delirious?
~Amanda
Old Nov 11, 2003 | 12:26 PM
dodgefreak's Avatar
dodgefreak
What are you going to do with your 4:10s if you get the new truck??
If you have the option of taking them out and putting the stock ones in let me know
Old Nov 11, 2003 | 01:36 PM
Iggster's Avatar
Iggster
Ok here goes...there is a noticeable gas difference between the two...with the 3.92 axle you will notice the truck runnin at higher rpm's and therefor using more gas. an average of 1-2 mpg more. so to answer your question the 3.92 is made for haulin...the 3.55 is a cruisin gear that can tow but is a lil easier on gas. What is the trailer weight that you normally tow?</P>
</P>
Old Nov 11, 2003 | 01:37 PM
Iggster's Avatar
Iggster
not gear...axle...sorry</P>
</P>
Old Nov 11, 2003 | 03:30 PM
Ram Off Road
I would say that the total weight would be around 2 to 2 1/2 tons. This would only occur a few times a year. Also, is there a big difference in acceleration between the two axles?
Old Nov 11, 2003 | 05:28 PM
Iggster's Avatar
Iggster
ok here is where it gets fun...if you are talking about a hemi i would stick with the 3.55 it has all the power you need for what you haul and won't sacrifice gas milage...if it is the 4.7l v8 then go with the 3.92..the sheer difference in power between the two engines is the factor...yes you will notice the 3.92 take off a little better but is it worth takin a hit on gas mileage when gas is so expensive...so this is just my input and how i would present it to you if you were here buying it from me! <IMG src=smileys/smiley1.gif border="0">
Old Nov 11, 2003 | 05:45 PM
Iggster's Avatar
Iggster
so does all this make sense?<IMG src=smileys/smiley12.gif border="0">
