Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
torque management on an 03 hemi
Old Jun 7, 2004 | 03:33 PM
bryanhastings's Avatar
bryanhastings
Default torque management on an 03 hemi
does anyone know how to bypass the torque management on a 03 hemi i really want to find out becase i put 22s and it is not as fast as it was and i need more power
Old Jun 7, 2004 | 04:12 PM
HEMI X's Avatar
HEMI X
Default RE: torque management on an 03 hemi
There is a wire behind the air filter box some guys cut. Not sure which one, I wil try and find a link.
Old Jun 7, 2004 | 04:30 PM
HEMI X's Avatar
HEMI X
Try this:
http://dtw.truckmoxie.com/forums/top...1324&q=tcm+mod
Old Jun 7, 2004 | 05:19 PM
B12Teuton's Avatar
B12Teuton
From reading several threads about it, it sounds like disconnecting that wire does the same thing to an '03 that the new tow/haul button does on the '04. The tow/haul mode is supposed to make shifts stronger and let it hold gears longer, right?
Has anyone driven their '04 around with this button pushed wile NOT towing?
Any reason to think this would screw up anything?
Old Jun 7, 2004 | 07:44 PM
slvrmagnum's Avatar
slvrmagnum
I dont know if it does the same thing the tow/haul does, but I know you can disconnect the wire in question. Most people that i have heard that have done this noticed a difference. Also, if I am not mistaken, the tow haul button also does not allow use of 5th gear and allows the use of each gear longer... I will try to find the information and post it here.
Old Jun 7, 2004 | 09:05 PM
slvrmagnum's Avatar
slvrmagnum
Here is what I found, this will only work on the '03's, will not work on the '04's like I have...[:@]
"The Next Gen Controller (PCM) is located on the firewall on the passenger's side, behind the airbox. On the 5.7L the wire is on the bottom connector(C4), No. 7 Pin; and on the 3.7L it is on the next to the bottom connector(C3), No. 13 Pin. It is easier to get to if you remove the top of the air cleaner box."
Old Jun 8, 2004 | 05:52 AM
bryanhastings
took me a little bit to do it wiht a phone screen as light but i got the job done too tired to drvie it tonight cant waith to test it in the morning post effects tomorrow
