Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Tune Ups
Old Jun 9, 2004 | 10:39 PM
Mikeg1005's Avatar
Mikeg1005
Default Tune Ups
Anyone here do their own tune ups on their truck(s)? I have a 98' Ram 1500 5.9L 4WD. I was wondering a few things, where is the PCV valve so that you can replace it. Also how would you check your timing chain or belt timing so that its set right? Can you do that or do you need a machanic for something like that.
Well, just a few questions, and I was wondering what all of you do on your tune ups and how often you do this stuff, and does it pay off instead of a machanic doing it.
Old Jun 10, 2004 | 01:41 AM
GaDodge's Avatar
GaDodge
Default RE: Tune Ups
Hey mike ur pcv should be stuck in your valve cover with a tube running to your throttle body or intake manifold. far as your timing goes its computer controlled and you would need a OBD2 scan tool to check it other than that whatever you maintenance guid says on timing chain replacement or call a dealer and ask them hope this helps you out .
