Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
jET CHIP #2
Old Jun 25, 2004 | 11:56 PM
silverRam's Avatar
silverRam
Default jET CHIP #2
PUT IN THE JET CHIP STAGE 2.. I DONT SEE MUCH OF A DIFFERENCE BUT A QUICKER SHIFT. I HAVE MAC AIR INTAKE AND CAT-BACK, THROTTLE BODY SPACER AND RUNNING 93 OCTANE.
IT RECOMENDS A 180 DEGREE THERMOSTAT BUT CANT FIND ONE
HAS ANYONE ELSE PUT THE CHIP ON AND WHAT WHERE YOUR FINDINGS
Old Jun 26, 2004 | 01:50 AM
dodge_sst1's Avatar
dodge_sst1
Default RE: jET CHIP #2
could not tell any differance with chip,the most differance is only from disconnecting power from ecm, it has to relearn agin.
Old Jun 26, 2004 | 06:39 AM
Matrix04's Avatar
Matrix04
how do you disconnect power from ecm properly?
Old Jun 26, 2004 | 07:31 AM
RuckstaR's Avatar
RuckstaR
Just remove negative battery lead. Should take a couple hours, but might as well just do it at night n put it back on in thye morning.
Old Jun 26, 2004 | 10:29 AM
dodgeramnz's Avatar
dodgeramnz
the quick way is to disconnect battery negative, turn ignition to on position then back off. that resets the pcm,
