Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
91 1 ton rear brakes not grabbing
Old Jul 8, 2004 | 09:57 AM
massie's Avatar
massie
Default 91 1 ton rear brakes not grabbing
i just replaced the rear brakes and they are not holding, i adjusted them to where they were rubbing pretty good , do you have to bleed them?
Old Jul 8, 2004 | 10:22 AM
JCswm's Avatar
JCswm
Default RE: 91 1 ton rear brakes not grabbing
not unless you replaced the wheel cylinders
you might need to adjust them again or the cylinders might be seized
if you did NOT open the system pull a drum, have someone push the brake pedal slowly, and make sure the cylinders are working
Or do you mean the parking brake won't hold???
