Dodge RamThe full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
I have a 96 Ram 1500 V8, 318. My truck Has 86,000 miles on the motor and I can't seem to keep oil in the engine. There are no signe of a bad head gasket to my knowledge. I have noticed that the 8th cylnder plug is covered inoil. Could some one help me figure out the problem</P>
Sounds like you might have a bad piston ring because oil isn't supposed to get in the combustion chamber...When you are driving does your exhaust have a blueish tint to it?
I had the same problem with my 2001 with only 47000 miles, I took it to the dealer and they found a bad intake manifold gasket. Don't know if you have the same problem, but you might want to have it checked out
try checking the compression on that cylinder and compare it with the other seven and that might help you see if rings are bad also if could be a bad valve guide.
