Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Doing away with leaf suspensions
Old Oct 30, 2006 | 01:16 AM
4x4oli's Avatar
4x4oli
Default Doing away with leaf suspensions
Does anyone have information on this? When I had just bought the Ram I remember reading about this, now I'm curious if I can attempt it. I'm not necessarily talking about going for an airbag suspension.
Old Nov 2, 2006 | 05:09 PM
Silver_Dodge's Avatar
Silver_Dodge
Default RE: Doing away with leaf suspensions
Only other option besides air I can think of would be to custom make an independent rear suspension setup.
Old Nov 2, 2006 | 10:06 PM
4x4oli's Avatar
4x4oli
The only company that I know makes a fully independent rear suspension on a vehicle as big as a ram (or almost) is ford on the explorers... Other than that, I still think it would be too much custom work for my skill and time i have available.
Old Nov 2, 2006 | 10:22 PM
Silver_Dodge
Any particular reason you want to do away with the leafs?
Old Nov 2, 2006 | 11:36 PM
4x4oli's Avatar
4x4oli
The *** end bounces around way too much, even for a truck. I've driven some GMs and they ride hard, for sure, and of course the Fords ride a little soft, but neither of them have an unbalanced back end like the Rams, even the 3rd gen have the same problem. The winters require a little soft ride in the back in order to have good handling. I drove an Impreza and an A4 before this truck so I guess i'm just a little picky about the winter handling.
Old Nov 5, 2006 | 05:38 PM
DsStang25's Avatar
DsStang25
Might want to try a airbag setup with softer springs so it rides softer when not towing or having weight in the bed. Make sure you get the right kind of springs though, otherwise itll just ride lower..
