Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Ram sport headlight conversion
Old Nov 10, 2006 | 02:06 AM
must6655's Avatar
must6655
Default Ram sport headlight conversion
HI,
I am sure someone has asked this before but I'm new to the forum.
I have a 1998 Ram 1500 that is not a sport and the headlights are the worst I've ever encountered!
How can I convert my headlights to the Sport headlights?
I have a pair of the sport lights but how can I hook them up properly?
I don't want to burn up any of my wiring and I know there is a proper way to do it.
Any help would be greatly appreciated!
Thanks!
Old Nov 10, 2006 | 04:09 AM
ryans590's Avatar
ryans590
Default RE: Ram sport headlight conversion
do you have the wireing from the sprot too, youll need it then just take the 3 wires hook hi beam power to high beam plug off the sport then run the outher to ground, same with lo beam...to put in the sport headlight assy you will need to trim the inner fender a bit too
also if you post in the 2nd gen fourm youll get alot more responces
Old Nov 10, 2006 | 01:04 PM
charginscott's Avatar
charginscott
I have a 2000 Ram Sport and always seen that replacement lights(aftermarket) were different for the sport, never knew why.
Scott
Old Nov 15, 2006 | 01:54 PM
steve05ram360's Avatar
steve05ram360
there is a wiring harness you can buy to simplify the install.... I did this mod on my 2000 and loved it.
http://www.pavementsucks.com/forums/...6547&old=78064 <- should help you out...
