Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
YEA ANOTHER TRANSMISSION PROBLEM
Old Jul 28, 2004 | 10:57 PM
1999 RAM's Avatar
1999 RAM
Default YEA ANOTHER TRANSMISSION PROBLEM
HI EVERYONE IM JOE. THANKS FOR LOOKING AT MY QUESTION. I HAVE A 99 DODGE RAM 1500. 2WD AND AUTOMATIC. THE PROBLEM IM HAVING IS WITH OVERDRIVE. THE OVERDIRVE SEEMS TO HANG UP WHEN I GET TO THE POINT IT SHOULD SHIFT INTO IT. AND WHEN IT GOES INTO OVERDRIVE IF I LET OFF THE THROTLE IT SHIFTS BACK INTO 3RD GEAR. WHEN I COME TO A STOP IFEEL IT DOWN SHIFT PRETTY HARD. IT SEEMS TO HAPPEN AFTER I DRIVE IT FOR A WHILE. SOMETIMES IT CAN GO ALL DAY WITH NO PROBLEMS. ANY COMMENTS WOULD BE APPRECIATED.
Old Jul 29, 2004 | 12:55 AM
BULLDOG's Avatar
BULLDOG
Default RE: YEA ANOTHER TRANSMISSION PROBLEM
It certainly seems well overdue for tranny maintenance! Regular maintenance, full fluid change is 100% necessary. In order to achieve this you need to remove all the fluid, this can be somewhat hard at home as you need to drain the converter, and cooler, ect. Doing a couple of back to back "drain & flush" sequences will normally adequate.
Overdrive is electric, commanded by a solenoid, I'm assuming that pump pressure is not up to par or just simply gummed up due to burned fluid.
I have seen this problem time and time again due to lack of maintenance.
Please elaborate further.
