Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Towing ???'s
Old Aug 3, 2004 | 11:29 PM
lilmill's Avatar
lilmill
Default Towing ???'s
What is the capacity of a 04 qc with the 3.92 's and tow package. I'm looking at trailering a supra to vegas. And wondering if I need anything like trailer brakes. I was told by a friend that you cannot flt tow with less than a 2500.
Old Aug 3, 2004 | 11:42 PM
BULLDOG's Avatar
BULLDOG
Default RE: Towing ???'s
Well I'm in a 2000 QC 5.9 and constantly two heaver items to Vegas without a problem. I do however use trailer brakes. I'm in Victorville, and do this often in the summer months, during the off-road race season.
Old Aug 4, 2004 | 03:37 PM
B12Teuton's Avatar
B12Teuton
ORIGINAL: lilmill
That's ridiculous!! You can safely tow around 9000lbs with the right setup on a 1500. The hitch is a class 4 which is rated for 12,000lbs and 1,200lb tongue weight.
Yes, you should have a trailer with brakes... but that applies to a 2500 and 3500 just the same. I would only consider a 2500 or 3500 if you have a goose-neck / fifth wheel and over 10,000. You have maybe 1/2 that.
Old Aug 4, 2004 | 06:32 PM
HEMIDAZE's Avatar
HEMIDAZE
Every state requires trailer brakes for trailers weighing above a certain weight. Most are somewhere around 1500 to 2000 lbs. Whatever it is in your state you can be sure you are exceeding it. You DO need trailer brakes!
