Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
proper bearing install
Old Dec 18, 2003 | 01:29 AM
dasgift's Avatar
dasgift
Default proper bearing install
i just bought a 85 sno commander (w150, 1 ton front suspension 5 lug, 4wd). My front wheel bearings decided to give up on me. the local parts store does not stock the book, nor do i the funds to purchase one. all i need to know how to properly install these front wheel bearings. any help is greatly appreciated!
Old Dec 18, 2003 | 12:53 PM
dodgefreak's Avatar
dodgefreak
just take your rotor in to the auto parts store and they should have a tool to pull the bearing out (if they have a machine shop) if not you can carfully do it your self with a screwdriver or a small pry bar.</P>
fill your palm with bearing grease and rub the bearing back and forth in the grease packing it onto the bearing as much as you can. </P>
</P>
coat the inside of the rotor with grease and set the bearing in the rotor. </P>
take a block of wood and place over the bearing and use a hammer (hitting the wood only) tap the bearing into the rotor!</P>
</P>
</P>
Old Dec 18, 2003 | 07:58 PM
dasgift's Avatar
dasgift
that would nice if my bearings were pressed in, which they are not. the hub rides on 2 bearings, which in turn, ride on the spindle which are held on by a nut, keyed washer, followed by a lock washer.
