Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Problem Diesel Shutdown
Old Dec 21, 2003 | 08:50 PM
OBIE's Avatar
OBIE
Default Problem Diesel Shutdown
<FONT face=Arial size=3>1995Dodge 2500 4 x4 Diesel Automatic Transmission has problem after 4 hrs. of highway travel at 70 MPH with cruise control on truck will shutter. I pulloff the road put transmission in neutral engine will reve up high then cut off, after 10 min. truck will starts normal, drives normal for the next 4 hrs. of trip. This is the 4th time in 4 years the same thing has happened. The last timeit happened the truck had 111,000 miles on it.</FONT></P>
<FONT face=Arial size=3>If anyone has had any of the above problems pleaserespond and let me know what your experiencewas.</FONT></P>
<FONT face=Arial size=3>Thanks,</FONT></P>
<FONT face=Arial size=3>OBIE</FONT></P>
Old Jan 26, 2004 | 08:39 AM
kenny's Avatar
kenny
HOW OFTEN DO YOU CHANGE THE FUEL FILTER? SHOULD EVERY YEAR. ALSO THE VACUUM PUMP CAN GIVE THIS SYMPTOM, IF HAS A LEAK. ARE YOU SHURE YOU DON'T HAVE A TRANS. PROBLEM. A BURNED TORQUE CONVERTER CAN CAUSE A SHUDDER. AND CAUSE THE ENG. TO STOP AT NEUTRAL, CAUSE IT'S LOCKED UP.
