Tisk tisk
I was driving and noticed this nasty noise when I make right turns. I think its my wheel hub or bearing. It only does it when I make a right hand turn and it went away earlier today but now is back. It sounds like metal. Anyways my question(s) are:
1: Can I buy a Hub w/o ABS because ABS on my truck is pointless.
2: I thought maybe its just frozen between when I put it in 4wd, it just stays locked up.
I don't know what you guys think... lemme know
I don't have a solution, but I think I have the same problem. Mine sounds like a squealing sound when the car is moving. It does not make noise all the time, but when it starts to squeal, it really sounds bad. Let me know if replacing the hub bearing fix's your problem. Thank you.
yep, its been recalled..... call your dealer and give them your vin, they'll tell you...
Trending Topics
Here is the link from this site that talks about it.
https://dodgeforum.com/m_705680/tm.htm
Hope it works. Good luck with the fix. Red
