Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
clutch position switch
Old Feb 28, 2007 | 03:21 PM
rburnham's Avatar
rburnham
Default clutch position switch
I have an '01 Ram. Is it possible to bypass the clutch position switch? Switch is out of adjustment/defective and I will be looking at it this PM. If it is defective I would like to simply bypass it electrically if it is relatively easy.
Thanks for your help!
Old Feb 28, 2007 | 07:17 PM
Drew's Avatar
Drew
Default RE: clutch position switch
you should be able to just jumper the wires together for the time being untill you get a new one or get it adjusted since it is only a simple switch.
