Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
where to put tempature sending unit for autometer water temp gauge eli
Old Mar 4, 2007 | 02:41 PM
wooziewaz's Avatar
wooziewaz
Default where to put tempature sending unit for autometer water temp gauge eli
do 5.7 have block drainplugs can i put sender where drain plug goes or do i get addapter for upper hose. thank you jim wayts.
Old Mar 4, 2007 | 03:44 PM
Captain Squalus's Avatar
Captain Squalus
Default RE: where to put tempature sending unit for autometer water temp gauge eli
Putting the sensor in the block drains would give you a false reading (colder than actual)
Cool water from the radiator enters the lower part of the block then travels upward through the block to the heads then to the thermostat.
Most of your heat is generated in the heads.
The proper place would be on the engine side of the thermostat as close as possable to the thermostat.
This position would give you the most accrurate reading of the coolant temerature.
Old Mar 5, 2007 | 12:51 PM
USA1Ram's Avatar
USA1Ram
