Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
FRONT AXLE U-JOINT???
Old Mar 24, 2007 | 02:27 PM
kegger503's Avatar
kegger503
Default FRONT AXLE U-JOINT???
98 DODGE RAM, 4X4, V8- CLICKING NOISE WHEN TURNING, SHARP TURNS MAKE IT WORSE. TOLD IT'S A BAD FRONT AXLE U-JOINT ON THE DRIVER'S SIDE??? DID NOT KNOW RAM'S HAD A U-JOINT IN THE FRONT AXLE, SO ANY HELP WOULD BE WELCOME ON THIS ISSUE!!!!
Old Mar 24, 2007 | 08:11 PM
kurts2's Avatar
kurts2
Default RE: FRONT AXLE U-JOINT???
It' not really a UV, I'd call it more of a CV, but in a 4X4 yes! You have front axels with "joints" on a 4X4 (call them what you will). When one goes bad, it can cause a vibration, expesially in turns and acceleration. It sounds like you had a good evaluation on the malfunction, only it "stimed" you because you didn't understand what you were told.
