Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
turn signal not working - easy fix??
Old Mar 27, 2007 | 12:08 PM
LBs Laramie's Avatar
LBs Laramie
Default turn signal not working - easy fix??
ok, so the bulb is not out as it still lights up when the parking lights are on, but no turn signal.is this an easy fix?i tried to take the headlight harness out yesterday to look at it, but i couldn't even get the thing out - i had all 3 bolts out (2 on the side, and 1 stuck underneath the headlight in the middle) and even tried unscrewing those 2 long bolts, but they wouldn't come out. can someone please help?? THANKS!!
Old Mar 27, 2007 | 01:59 PM
kurts2's Avatar
kurts2
Default RE: turn signal not working - easy fix??
Some bulbs have more than one filiment (and contact set). I'm not sure if yours does, but I'd try a bulb before a harness change anyday!
Old Mar 27, 2007 | 02:43 PM
bigjrussell's Avatar
bigjrussell
Yeah, definitely check the bulb first, and you don't need to take the headlight assembly out to do this. Where the harness meets the bulb on the back of the housing, there is a rotating assembly that you just rotate until the tabs line up with the openings and then you just pull the bulb out. Those 2 screws on top most times are the headlight adjustor screws. You may have thrown your headlight out of alignment. To fix it, check your owner's manual. Pretty simple.
Old Mar 27, 2007 | 02:54 PM
LBs Laramie
thats partly the problem - i can't even pull the headlight housing out in order to get to the back of it toeven try a simple bulb replace...
Old Mar 27, 2007 | 03:05 PM
bigjrussell
https://dodgeforum.com/m_227638/tm.htm
This is for modding your headlights, but he does go through how to pull it out. I imagine that '02-'05 should all be the same procedure.
Old Mar 27, 2007 | 05:12 PM
LBs Laramie
great- thank you!
