Dodge Sprinter The Dodge Sprinter is all function, with styling cues from the Dodge Truck line, it makes the workaholic's job much easier. Check out the Dodge Sprinter in showrooms today!
Missing Transmission Filler Tube Cap
Old Apr 4, 2007 | 01:36 PM
jerry_in_Dewey_arizo's Avatar
Default Missing Transmission Filler Tube Cap
I purchased and received a transmission dip stick measuring device. I just went out to my 2006 Pleasure-Way Sprinter motorhome and tried the dipstick. I noticed that there is no cap or anything on the end of the tube where the dipstick goes in. In other posts I have read about a cap. The dipstick worked fine.
So my question is should I leave the end of the tube open , or buy the cap from a Dodge dealer, or put a plastic bag over the opening with a fastener?
Old Apr 4, 2007 | 02:44 PM
2 sadlers's Avatar
2 sadlers
Default RE: Missing Transmission Filler Tube Cap
Don't leave the tube open. You'll need a cap and a retainer clip that holds the cap on. You can get both of at http://www.europarts-sd.com/get-pdf....247993f8899cbcThe cap
# 140-270-00-91 at $2.65 EA and the cap lock pin # 140-991-00-55 at $.70 EA. I got a few eatra cap lock pins, you can reuse the fill tube cap.
