Dodge Sprinter The Dodge Sprinter is all function, with styling cues from the Dodge Truck line, it makes the workaholic's job much easier. Check out the Dodge Sprinter in showrooms today!
Itasca Navion Dodge Sprinter Chassis
Old Jun 24, 2007 | 10:02 PM
bnewland's Avatar
bnewland
Default Itasca Navion Dodge Sprinter Chassis
Trans won't shift down and engine is losing power - can drive by manually shifting to lower gears on hills etc. Engine check lite is on when engine is running. What is the problem?
Old Sep 12, 2007 | 12:16 AM
ratchett11's Avatar
ratchett11
Default RE: Itasca Navion Dodge Sprinter Chassis
sounds kind of like a governor pressure solenoid or possible worn out fluid or pluged filter. Maybe something else in the valve body, Call the local dealer.
