Dodge Sprinter The Dodge Sprinter is all function, with styling cues from the Dodge Truck line, it makes the workaholic's job much easier. Check out the Dodge Sprinter in showrooms today!
2006 Sprinter Brake Bleeding?
Old Dec 1, 2007 | 12:33 PM
danyenkale's Avatar
danyenkale
Default 2006 Sprinter Brake Bleeding?
I replaced pads, rotors, calipers on an 06 sprinter. When the van is off the brake pedal is fine when the van is on the pedal goes to the floor. I dont think its the master cyclinder so my only other guess is I bled the brakes in the wrong order. Does anyone know the correct order of bleeding the brakes? Or somewhere I can go to for help? I need this done ASAP and the only dealership that I know of who works with these is closed til monday. Help!!
Old Dec 23, 2007 | 03:43 PM
vpracegasatlanta's Avatar
vpracegasatlanta
Default RE: 2006 Sprinter Brake Bleeding?
My Sprinter service center did all of that in the same job. Brakes, sensors,and brake fluid flush all included. Made it good as new.
Old Jan 31, 2008 | 07:52 PM
ancote's Avatar
ancote
You usely start by the closest of the master cylinder like driver side first, than other side and back.
Are you sure that you did empty the master while bleeding ?
