Dodge Sprinter The Dodge Sprinter is all function, with styling cues from the Dodge Truck line, it makes the workaholic's job much easier. Check out the Dodge Sprinter in showrooms today!
2009 3.0 turbo diesel
Old Jan 22, 2010 | 03:43 PM
master tech's Avatar
master tech
Site Moderator & Tech
Default 2009 3.0 turbo diesel
MODULE, Engine Control (ECM)
Diagnosis and Testing
0100-MASS AIR FLOW SENSOR SIGNAL VOLTAGE TOO HIGH
0100-MASS AIR FLOW SENSOR SIGNAL VOLTAGE TOO LOW
0105 TURBO BOOST PRESSURE SENSOR SIGNAL VOLTAGE TOO HIGH
0105-TURBO BOOST PRESSURE SENSOR SIGNAL VOLTAGE TOO LOW
0105-TURBO BOOST PRESSURE SENSOR SIGNAL CORRELATION WITH ATMOSPHERE PRESS SENSOR
0110 INTAKE AIR TEMPERATURE SENSOR CAN SIGNAL FAULT
0110 INTAKE AIR TEMPERATURE SENSOR SIGNAL VOLTAGE TOO HIGH
0110 INTAKE AIR TEMPERATURE SENSOR SIGNAL VOLTAGE TOO LOW
0115 ENGINE COOLANT TEMPERATURE SENSOR SIGNAL VOLTAGE TOO HIGH
0180 FUEL TEMPERATURE SENSOR SIGNAL VOLTAGE TOO HIGH
0180 FUEL TEMPERATURE SENSOR SIGNAL VOLTAGE TOO LOW
0190 FUEL RAIL PRESSURE SENSOR SIGNAL VOLTAGE TOO HIGH
0190 FUEL RAIL PRESSURE SENSOR SIGNAL VOLTAGE TOO LOW
0201 FUEL INJECTOR 1 CIRCUIT GENERAL ERROR
0201 FUEL INJECTOR 1 CIRCUIT SHORT CIRCUIT
0201 FUEL INJECTOR 1 CIRCUIT SHORT TO GROUND
0201-FUEL INJECTOR 1 CIRCUIT SHORT TO VOLTAGE
0202 FUEL INJECTOR 2 CIRCUIT GENERAL ERROR
0202 FUEL INJECTOR 2 CIRCUIT SHORT CIRCUIT
0202-FUEL INJECTOR 2 CIRCUIT SHORT TO GROUND
0202 FUEL INJECTOR 2 CIRCUIT SHORT TO VOLTAGE
0203 FUEL INJECTOR 3 CIRCUIT GENERAL ERROR
0203 FUEL INJECTOR 3 CIRCUIT SHORT CIRCUIT
0203 FUEL INJECTOR 3 CIRCUIT SHORT TO GROUND
0203 FUEL INJECTOR 3 CIRCUIT SHORT TO VOLTAGE
0204 FUEL INJECTOR 4 CIRCUIT GENERAL ERROR
0204 FUEL INJECTOR 4 CIRCUIT SHORT CIRCUIT
0204 FUEL INJECTOR 4 CIRCUIT SHORT TO GROUND
0204 FUEL INJECTOR 4 CIRCUIT SHORT TO VOLTAGE
0205-CYLINDER 5 INJECTOR SIGNAL CIRCUIT
0205 FUEL INJECTOR 5 CIRCUIT GENERAL ERROR
0205 FUEL INJECTOR 5 CIRCUIT SHORT CIRCUIT
0205 FUEL INJECTOR 5 CIRCUIT SHORT TO GROUND
0205 FUEL INJECTOR 5 CIRCUIT SHORT TO VOLTAGE
0206 FUEL INJECTOR 6 CIRCUIT GENERAL ERROR
0206 FUEL INJECTOR 6 CIRCUIT SHORT CIRCUIT
0206-FUEL INJECTOR 6 CIRCUIT SHORT TO GROUND
0206-FUEL INJECTOR 6 CIRCUIT SHORT TO VOLTAGE
0300-MULTIPLE CYLINDER MISFIRE
0675-CYLINDER 5 GLOW PLUG OPEN CIRCUIT
0675-CYLINDER 5 GLOW PLUG OVERTEMPERATURE
0675-CYLINDER 5 GLOW PLUG SHORT CIRCUIT
0676-CYLINDER 6 GLOW PLUG OVERTEMPERATURE
1105-BARO PRESSURE SENSOR CORRELATION WITH LOAD PRESS SENSOR
1105-BARO PRESSURE SENSOR VOLTAGE TOO HIGH
1105-BARO PRESSURE SENSOR VOLTAGE TOO LOW
1222-ACCELERATOR PEDAL POSITION SENSOR 1 SIGNAL VOLTAGE TOO HIGH
1222-ACCELERATOR PEDAL POSITION SENSOR 1 SIGNAL VOLTAGE TOO LOW
1222-ACCELERATOR PEDAL POSITION SENSOR 1 / 2 CORRELATION
1234-ACCELERATOR PEDAL POSITION SENSOR 2 SIGNAL VOLTAGE TOO HIGH
1234-ACCELERATOR PEDAL POSITION SENSOR 2 SIGNAL VOLTAGE TOO LOW
1234-ACCELERATOR PEDAL POSITION SENSOR 1 / 2 CORRELATION
1436-EXHAUST GAS TEMPERATURE SENSOR 1/1 VOLTAGE TOO HIGH
1436-EXHAUST GAS TEMPERATURE SENSOR 1/1 VOLTAGE TOO LOW
1437-EXHAUST GAS TEMPERATURE SENSOR 1/2 VOLTAGE TOO HIGH
1437-EXHAUST GAS TEMPERATURE SENSOR 1/2 VOLTAGE TOO LOW
1480-GLOW PLUG DISPLAY CAN DEFECT
1482-GLOW OUTPUT STAGE COMMUNICATION FAULT
1482-GLOW OUTPUT STAGE COMPONENT FAULTY
1482-GLOW OUTPUT STAGE FAULT
1482-GLOW OUTPUT STAGE SHORT CIRCUIT
1610-VOLTAGE REGULATOR DE-ENERGIZES TOO LATE
1610-VOLTAGE REGULATOR DE-ENERGIZES TOO SOON
1610-VOLTAGE REGULATOR STUCK
1611-SENSOR REFERENCE 1 SIGNAL VOLTAGE TOO HIGH
1611-SENSOR REFERENCE 1 SIGNAL VOLTAGE TOO LOW
1612-MAX GOV SPEED DEVIATION NO SIGNAL
1612-MAX GOV SPEED DEVIATION PLAUSIBILITY ERROR
1617-ECU INTERNAL EEPROM ERROR
1630 DRIVE AUTHORIZATION SYSTEM COMMUNICATION ERROR WITH EIS (CGW)
1630-DRIVE AUTHORIZATION SYSTEM EEPROM ERROR
1630 DRIVE AUTHORIZATION SYSTEM INHABITED KEY
1630 DRIVE AUTHORIZATION SYSTEM INVALID AUTHENTICATION VALUE
1681 CRASH SIGNAL ENGINE SHUTDOWN REQUESTED BY ORC
2008-FUEL RAIL PRESSURE SENSOR OFFSET TEST HIGH
2008-FUEL RAIL PRESSURE SENSOR OFFSET TEST LOW
2009-WATER IN FUEL SENSOR FAULTY COMPONENT
2009-WATER IN FUEL SENSOR WATER IN FILTER
2010-MASS AIR FLOW SENSOR SIGNAL VOLTAGE TOO HIGH
2010-MASS AIR FLOW SENSOR SIGNAL VOLTAGE TOO LOW
2011-CHARGE AIR SYSTEM / MASS AIR FLOW SENSOR SIGNAL DEVIATION TOO HIGH
2011-CHARGE AIR SYSTEM / MASS AIR FLOW SENSOR SIGNAL DEVIATION TOO LOW
2012-ENGINE COOLANT TEMPERATURE SENSOR SIGNAL IMPLAUSIBLE
2013-AMBIENT AIR TEMPERATURE CAN SIGNAL FAULTY
2014-ENGINE OIL TEMPERATURE SENSOR SIGNAL VOLTAGE TOO HIGH
2014-ENGINE OIL TEMPERATURE SENSOR SIGNAL VOLTAGE TOO LOW
2014-ENGINE OIL TEMPERATURE SENSOR TEMPERATURE IMPLAUSIBLE
2015-FUEL RAIL PRESSURE SENSOR SIGNAL VOLTAGE TOO LOW
2016-FUEL RAIL PRESSURE REDUCTION DURING DECEL IMPLAUSIBLE
2016-FUEL RAIL PRESSURE SENSOR SIGNAL VOLTAGE TOO LOW
2016-FUEL RAIL PRESSURE STANDARD DEVIATION IN DECEL MODE
2016-FUEL RAIL PRESSURE STANDARD DEVIATION IN IDLE
2017-FUEL RAIL PRESSURE SENSOR SIGNAL VOLTAGE TOO LOW
2018-FUEL RAIL PRESSURE SENSOR SIGNAL VOLTAGE TOO HIGH
2019-FUEL RAIL PRESSURE SENSOR SIGNAL VOLTAGE TOO LOW
2019-FUEL RAIL PRESSURE SENSOR SIGNAL VOLTAGE TOO LOW FOR ENGINE SPEED
2020-FUEL RAIL PRESSURE SNSR SGNL VOLTAGE TOO LOW FOR THE PRESS REG VLV
2020-FUEL RAIL PRESSURE SENSOR SIGNAL VOLTAGE TOO HIGH
2021-FUEL RAIL PRESSURE SENSOR SIGNAL VOLTAGE TOO LOW
2023-FUEL RAIL PRESSURE SENSOR MAXIMUM PRESSURE HAS BEEN EXCEEDED
2024 INTAKE AIR TEMPERATURE SENSOR SIGNAL VOLTAGE TOO HIGH
2024 INTAKE AIR TEMPERATURE SENSOR SIGNAL VOLTAGE TOO LOW
2025-INTAKE MANIFOLD PRESSURE SENSOR CORRELATION WITH ATMOSPHERE PRESSURE SENSOR
2025-INTAKE MANIFOLD PRESSURE SENSOR SIGNAL FAULTY
2025-INTAKE MANIFOLD PRESSURE SENSOR SIGNAL VOLTAGE TOO HIGH
2025-INTAKE MANIFOLD PRESSURE SENSOR SIGNAL VOLTAGE TOO LOW
2026-02 SENSOR BATTERY FAULTY
2026-02 SENSOR OPEN CIRCUIT
2026-02 SENSOR SHORT TO GROUND
2026-02 SENSOR SHORT TO VOLTAGE
2028-02 SENSOR PUMP CURRENT BATTERY FAULTY
2028-02 SENSOR PUMP CURRENT OPEN
2028-02 SENSOR PUMP CURRENT SHORT TO GROUND
2028-02 SENSOR PUMP CURRENT SHORT TO VOLTAGE
2030-02 SENSOR GROUND CIRCUIT BATTERY FAULTY
2030-02 SENSOR GROUND CIRCUIT OPEN
2030-02 SENSOR GROUND CIRCUIT SHORT TO GROUND
2030-02 SENSOR GROUND CIRCUIT SHORT TO VOLTAGE
2032-02 SENSOR SIGNAL VOLTAGE TOO HIGH
2032-02 SENSOR SIGNAL VOLTAGE TOO LOW
2034-02 SENSOR CALIBRATION 02 VALUE TOO HIGH
2034-02 SENSOR CALIBRATION 02 VALUE TOO LOW
2036-02 SENSOR CALIBRATION VALUE TOO HIGH
2036-02 SENSOR CALIBRATION VALUE TOO LOW
2038-02 SENSOR RESISTANCE TOO HIGH
2038-02 SENSOR RESISTANCE TOO LOW
2040-ENGINE OIL SENSOR LEVEL INVALID VALUE
2040-ENGINE OIL SENSOR LEVEL IMPLAUSIBLE
2040-ENGINE OIL SENSOR LEVEL TOO HIGH
2062-ENGINE OIL SENSOR SIGNAL FAULTY
2062-ENGINE OIL SENSOR ERROR IN PULSE MONITORING
2040-ENGINE OIL SENSOR ERROR IN MONITORING SYNCHRONIZATION PAUSE
2040-ENGINE OIL SENSOR ERROR IN PULSE MONITORING
2041-ENGINE OIL SENSOR IMPLAUSIBLE
2041-ENGINE OIL SENSOR QUALITY INVALID VALUE
2041-ENGINE OIL SENSOR QUALITY IMPLAUSIBLE
2042-ENGINE OIL SENSOR WATER CONTENT TOO HIGH
2043-CAMSHAFT POSITION SENSOR NO SIGNAL
2043-CAMSHAFT POSITION SENSOR SIGNAL FAULTY
2045-CRANKSHAFT POSITION SENSOR NO SIGNAL
2045-CRANKSHAFT POSITION SENSOR SIGNAL FAULTY
2047-FUEL RAIL PRESSURE VOLUME CONTROL MAXIMUM PRESSURE HAS BEEN EXCEEDED
2051-FUEL RAIL PRESSURE SENSOR MAXIMUM PRESSURE HAS BEEN EXCEEDED
2052-FUEL RAIL PRESSURE SENSOR IMPLAUSIBLE
2054-ENGINE COOLANT TEMPERATURE SENSOR SIGNAL VOLTAGE TOO HIGH
2054-ENGINE COOLANT TEMPERATURE SENSOR SIGNAL VOLTAGE TOO LOW
2057-02 SENSOR HEATER SHORT TO PUMP CURRENT
2059-02 SENSOR PUMP CURRENT SIGNAL VOLTAGE TOO HIGH
2063-INTAKE AIR TEMPERATURE SENSOR SIGNAL VOLTAGE TOO HIGH
2063-INTAKE AIR TEMPERATURE SENSOR SIGNAL VOLTAGE TOO LOW
2065-MASS AIR FLOW SENSOR SIGNAL VOLTAGE TOO HIGH
2065-MASS AIR FLOW SENSOR SIGNAL VOLTAGE TOO LOW
2066-MASS AIR FLOW SENSOR DUTY CYCLE ABOVE LIMIT
2066-MASS AIR FLOW SENSOR DUTY CYCLE BELOW LIMIT
2066-MASS AIR FLOW SENSOR DUTY CYCLE OUTSIDE VALID RANGE
2067-MASS AIR FLOW SENSOR DUTY CYCLE ABOVE LIMIT
2067-MASS AIR FLOW SENSOR DUTY CYCLE BELOW LIMIT
2067-MASS AIR FLOW SENSOR DUTY CYCLE OUT OF RANGE
2069-EXHAUST TEMPERATURE SENSOR ABOVE RANGE
2069-EXHAUST TEMPERATURE SENSOR BELOW RANGE
2069-EXHAUST TEMPERATURE SENSOR INVALID
2069-EXHAUST TEMPERATURE SENSOR PLAUSIBILITY
2070-EXHAUST TEMPERATURE SENSOR ABOVE RANGE
2070-EXHAUST TEMPERATURE SENSOR BELOW RANGE
2070-EXHAUST TEMPERATURE SENSOR PLAUSIBILITY
2071 02 SENSOR SIGNAL IMPLAUSIBLE
2073 02 SENSOR SIGNAL IMPLAUSIBLE
2075 02 SENSOR SIGNAL IMPLAUSIBLE
2076 02 SENSOR REFERENCE CURRENT LOW
2078-DIFFERENTIAL PRESSURE SENSOR SIGNAL IMPLAUSIBLE
2078 DIFFERENTIAL PRESSURE SENSOR SIGNAL VOLTAGE TOO HIGH
2078 DIFFERENTIAL PRESSURE SENSOR SIGNAL VOLTAGE TOO LOW
2079 DIFFERENTIAL PRESSURE SENSOR ENGINE PROTECTION ACTIVE
2080 DIFFERENTIAL PRESSURE SENSOR DYNAMIC OFFSET
2081-DIFFERENTIAL PRESSURE SENSOR BLOCKED PRESSURE SENSOR
2081 DIFFERENTIAL PRESSURE SENSOR PRESSURE DIFFERENTIAL TOO HIGH
2081 DIFFERENTIAL PRESSURE SENSOR PRESSURE DIFFERENTIAL TOO LOW
2081-DIFFERENTIAL PRESSURE SENSOR PRESSURE TOO LOW
2082-DIFFERENTIAL PRESSURE SENSOR DEFECTIVE HOSE
2083-DIFFERENTIAL PRESSURE SENSOR BLOCKED PRESSURE SENSOR
2083-DIFFERENTIAL PRESSURE SENSOR PRESSURE TOO HIGH
2084-DIFFERENTIAL PRESSURE SENSOR AIR MASS TOO LARGE
2084-DIFFERENTIAL PRESSURE SENSOR AIR MASS TOO SMALL
2085-DIFFERENTIAL PRESSURE SENSOR CONTINUOUS REGENERATION ACTIVE
2086 DIFFERENTIAL PRESSURE SENOR PLAUSIBILITY (EXHAUST TEMP SENSOR)
2087 DIFFERENT PRESSURE SENSOR (AIR FILTER) DIRTY/CLOG
2088 INTAKE AIR TEMPERATURE SENSOR DUTY CYCLE
2088 INTAKE AIR TEMPERATURE SENSOR DUTY CYCLE OUT OF RANGE
2089-EXHAUST PRESSURE SENSOR SIGNAL IMPLAUSIBLE
2089-EXHAUST PRESSURE SENSOR VOLTAGE TOO HIGH
2089-EXHAUST PRESSURE SENSOR VOLTAGE TOO LOW
2100-FUEL LEVEL SENSOR OVERTEMPERATURE
2100-FUEL LEVEL SENSOR SIGNAL LINE INTERRUPTED
2100 FUEL LEVEL SENSOR SIGNAL SHORT TO GROUND
2100 FUEL LEVEL SENSOR SIGNAL SHORT TO VOLTAGE
2104-STARTER CONTROL SHORT TO VOLTAGE
2113 CYLINDER 1 MULTIPLE MISFIRE
2114-CYLINDER 2 MULTIPLE MISFIRE
2115 CYLINDER 3 MULTIPLE MISFIRE
2116-CYLINDER 4 MULTIPLE MISFIRE
2117-CYLINDER 5 MULTIPLE MISFIRE
2118-CYLINDER 6 MULTIPLE MISFIRE
2122-ENGINE SHUTOFF PATHS DEFECTIVE CONTROL LOOP
2122-ENGINE SHUTOFF PATHS OVERVOLTAGE
2122-ENGINE SHUTOFF PATHS UNDERVOLTAGE
2123-INJECTORS OUTPUT STAGE 1 - SHORT CIRCUIT TO GROUND
2123-INJECTORS OUTPUT STAGE 1 - SHORT CIRCUIT TO POSITIVE
2124-INJECTORS OUTPUT STAGE 2- SHORT CIRCUIT TO GROUND
2123-INJECTORS OUTPUT STAGE 2- SHORT CIRCUIT TO POSITIVE
2132-GLOW PLUG CONTROL CIRCUIT OPEN CIRCUIT
2132-GLOW PLUG CONTROL CIRCUIT OVERTEMPERATURE
2132-GLOW PLUG CONTROL CIRCUIT SHORT TO GROUND
2132-GLOW PLUG CONTROL CIRCUIT SHORT TO VOLTAGE
2133-CYLINDER 1 GLOW PLUG EXCESS TEMPERATURE
2133-CYLINDER 1 GLOW PLUG OPEN CIRCUIT
2133-CYLINDER 1 GLOW PLUG OUTPUT STAGE EXCESS TEMP
2133-CYLINDER 1 GLOW PLUG SHORT CIRCUIT
2134-CYLINDER 2 GLOW PLUG EXCESS TEMPERATURE
2134-CYLINDER 2 GLOW PLUG OPEN CIRCUIT
2134-CYLINDER 2 GLOW PLUG OUTPUT STAGE EXCESS TEMP
2134-CYLINDER 2 GLOW PLUG SHORT CIRCUIT
2135-CYLINDER 3 GLOW PLUG EXCESS TEMPERATURE
2135-CYLINDER 3 GLOW PLUG OPEN CIRCUIT
2135-CYLINDER 3 GLOW PLUG OUPUT STAGE EXCESS TEMP
2135-CYLINDER 3 GLOW PLUG SHORT CIRCUIT
2136-CYLINDER 4 GLOW PLUG EXCESS TEMPERATURE
2136-CYLINDER 4 GLOW PLUG OPEN CIRCUIT
2136-CYLINDER 4 GLOW PLUG OUTPUT STAGE EXCESS TEMP
2136-CYLINDER 4 GLOW PLUG SHORT CIRCUIT
2137-CYLINDER 5 GLOW PLUG EXCESS TEMPERATURE
2137-CYLINDER 5 GLOW PLUG OPEN CIRCUIT
2137-CYLINDER 5 GLOW PLUG OUTPUT STAGE EXCESS TEMP
2137-CYLINDER 5 GLOW PLUG SHORT CIRCUIT
2138-CYLINDER 6 GLOW PLUG EXCESS TEMPERATURE
2138-CYLINDER 6 GLOW PLUG OPEN CIRCUIT
2138-CYLINDER 6 GLOW PLUG OUTPUT STAGE EXCESS TEMP
2138-CYLINDER 6 GLOW PLUG SHORT CIRCUIT
2141-CYLINDER 1 INJECTOR SIGNAL CIRCUIT
2142-CYLINDER 2 INJECTOR SIGNAL CIRCUIT
2143 CYLINDER 3 INJECTOR SIGNAL CIRCUIT
2144-CYLINER 4 INJECTOR SIGNAL CIRCUIT
2145-CYLINDER 5 INJECTOR SIGNAL CIRCUIT
2146-CYLINDER 6 INJECTOR SIGNAL CIRCUIT
2149 - HIGH PRESSURE PUMP A-D IMPLAUSIBLE
2149-HIGH PRESSURE PUMP A-D VALUE ABOVE LIMIT
2149 - HIGH PRESSURE PUMP A-D VALUE BELOW LIMIT
2151 - PRESSURE REGULATOR VALVE A-D VALUE ABOVE LIMIT
2151 - PRESSURE REGULATOR VAVLE A-D VALUE BELOW LIMIT
2152-STARTER CONTROL SHORT TO GROUND
2153-STARTER CONTROL SIGNAL INTERRUPTED
2195-O2 SENSOR HEATER EXCESSIVE CURRENT
2195-O2 SENSOR HEATER SHORT TO GROUND
2195-O2 SENSOR HEATER SHORT TO VOLTAGE
2195-02 SENSOR HEATER SIGNAL
2197 - HIGH PRESSURE PUMP EXCESSIVE CURRENT
2197-HIGH PRESSURE PUMP SIGNAL INTERRUPTED
2198-HIGH PRESSURE PUMP SHORT TO VOLTAGE
2199-HIGH PRESSURE PUMP SHORT TO GROUND
2245- ALTERNATOR SIGNAL COMMUNICATION FAULT
2245-ALTERNATOR SIGNAL SHORT TO VOLTAGE
2247-ALTERNATOR BI SHORT TO GROUND
2247-ALTERNATOR BI SHORT TO VOLTAGE
2247-ALTERNATOR EXCESSIVE CURRENT
2248-ALTERNATOR ELECTRICAL FAULT
2249-ALTERNATOR MECHANICAL FAULT
2250-ALTERNATOR TEMPERATURE TOO HIGH OR TOO LOW
2257-GLOW PLUG CONTROL UNIT FAULTY
2257-GLOW PLUG CONTROL UNIT RELAY FAULTY
2257-GLOW PLUG CONTROL UNIT SUPPLY VOLTAGE LOW
2257-GLOW PLUG CONTROL UNIT POWER CONSUMPTION TOO HIGH
2266-LIN BUS FAULT
2267-GLOW OUTPUT STAGE COMMUNICATION FAULT
2268-LIN BUS ERROR
2270-GLOW OUTPUT STAGE EXCESS TEMPERATURE
2270-GLOW OUTPUT STAGE ONE PLUG NOT ACTUATED
2270-GLOW OUTPUT STAGE VOLTAGE SUPPLY TOO LOW
2271-ALTERNATOR LOAD SIGNAL EXCESSIVE CURRENT
2271-ALTERNATOR LOAD SIGNAL INTERRUPTED
2271-ALTERNATOR LOAD SIGNAL SHORT TO GROUND
2271-ALTERNATOR LOAD SIGNAL SHORT TO VOLTAGE
2272 DTC PRESENT IN TCM
2306-SENSOR REFERENCE VOLTAGE 2 CIRCUIT LOW
2306-SENSOR REFERENCE VOLTAGE 2 TOO HIGH
2319-A-D CONVERTER CONSEQUENTIAL FAULT
2319-A-D CONVERTER REFERENCE VOLTAGE TOO HIGH
2319-A-D CONVERTER REFERENCE VOLTAGE TOO LOW
2319-A-D CONVERTER TEST PULSE ERROR
2321-ECM INTERNAL FAULT
2322-REDUNDANT SHUTOFF MONITORING TORQUE REQUEST NOT PLAUSIBLE
2323-ECM INTERNAL FAULT
2324-ECM INJECTOR MONITORING COMMUNICATION FAULT
2324-ECM INJECTOR MONITORING ERROR DURING INITIALIZING
2324-ECM INJECTOR MONITORING INTERNAL FAULT
2324-ECM INJECTOR MONITORING TEST MODE
2325-ECM INJECTOR MONITORING INTERNAL FAULT
2325-ECM INJECTOR MONITORING PROGRAM FAULT
2325-ECM INTERNAL FAULT
2327-ACCELERATOR PEDAL POSITION MODULE SIGNAL IMPLAUSIBLE
2332-SENSOR REFERENCE VOLTAGE 3 CIRCUIT TOO LOW
2332-SENSOR REFERENCE VOLTAGE 3 TOO HIGH
2338 S/C EXCESSIVE DECELERATION
2339-VARIANT CODING CODING ERROR
2339-VARIANT CODING INTERNAL MEMORY ERROR
2339-VARIANT CODING INVALID CODING
2340-FUEL QUANTITY ADJUSTMENT NO SIGNAL
2342-ECU RUNTIME MANAGER INTERRUPT TIMEOUT
2342-ECU RUNTIME MANAGER INTERNAL TIMER DEVIATION
2347-VARIANT CODING CAN ERROR
2347-VARIANT CODING EEPROM FAULT
2347-VARIANT CODING TRANSMISSION INCORRECTLY CODED
2350-ECM VOLTAGE TOO LOW
2351-ECM VOLTAGE TOO HIGH
2352-ECU O2 CONTROL PLAUSIBILITY ERROR
2352-FUEL INJECTION HIGH VOLUMETRIC EFFICIENCY
2352-FUEL INJECTION INCORRECT SOFTWARE
2352-FUEL INJECTION INTERNAL TEMPERATURE
2352-FUEL INJECTION LOW INJECTION QUANTITY
2355-EXHAUST GAS RECIRCULATION CONTROL AIR MASS TOO LARGE
2355-EXHAUST GAS RECIRCULATION CONTROL AIR MASS TOO SMALL
2356-ECM RECOVERY ERROR
2357-ECM RECOVERY ERROR
2358-ECM RECOVERY ERROR
2359-BOOST PRESSURE SENSOR SIGNAL VOLTAGE TOO HIGH
2359-BOOST PRESSURE SENSOR SIGNAL VOLTAGE TOO LOW
2360-ECU INTERNAL FAULT
2360-ECU PROGRAM COMPATIBILITY ERROR
2360-ECU PROGRAM MEMORY ERROR
2364-ECU PROGRAM CODE FAULTY
2366-ECU O2 CONTROL VOLTAGE TOO LOW
2368 INJECTOR QUANTITY ADJUSTMENT ERROR CYLINDER 1
2368 INJECTOR QUANTITY ADJUSTMENT ERROR CYLINDER 2
2368 INJECTOR QUANTITY ADJUSTMENT ERROR CYLINDER 3
2369 INJECTOR QUANTITY ADJUSTMENT ERROR CYLINDER 4
2369 INJECTOR QUANTITY ADJUSTMENT ERROR CYLINDER 5
2369 INJECTOR QUANTITY ADJUSTMENT ERROR CYLINDER 6
2370-ECM INJECTOR SWITCH SHORT CIRCUIT
2371-THROTTLE VALVE ACTUATOR PLAUSIBILITY ERROR
2372-THROTTLE VALVE ACTUATOR JAMMED
2373-ECM INJECTOR SWITCH SHORT CIRCUIT
2374-ECM INJECTOR SWITCH VOLTAGE TOO HIGH
2374-ECM INJECTOR SWITCH VOLTAGE TOO LOW
2375-ECM INJECTOR SWITCH VOLTAGE TOO HIGH
2375-ECM INJECTOR SWITCH VOLTAGE TOO LOW
2376-EGR AIRFLOW THROTTLE CONTROL CIRCUIT PERFORMANCE
2376-EGR AIRFLOW THROTTLE CONTROL CIRCUIT SHORT TO GROUND
2376-EGR AIRFLOW THROTTLE CONTROL CIRCUIT SHORT TO VOLTAGE
2376-EGR AIRFLOW THROTTLE CONTROL OPEN CIRCUIT
2386-ECU INTERNAL FAULT
2387 INJECTOR QUANTITY ADJUSTMENT ERROR CYLINDER 1
2387 INJECTOR QUANTITY ADJUSTMENT ERROR CYLINDER 2
2387 INJECTOR QUANTITY ADJUSTMENT ERROR CYLINDER 3
2387 INJECTOR QUANTITY ADJUSTMENT ERROR CYLINDER 4
2388 INJECTOR QUANTITY ADJUSTMENT ERROR CYLINDER 5
2388 INJECTOR QUANTITY ADJUSTMENT ERROR CYLINDER 6
2389-THROTTLE VALVE ACTUATOR PERMANENT NEGATIVE DEVIATION
2389-THROTTLE VALVE ACTUATOR PERMANENT POSITIVE DEVIATION
2500-PRESSURE REGULATOR VALVE CIRCUIT EXCESSIVE CURRENT
2500-PRESSURE REGULATOR VALVE CIRCUIT OPEN
2501-PRESSURE REGULATOR VALVE CIRCUIT SHORT TO VOLTAGE
2502-PRESSURE REGULATOR VALVE CIRCUIT SHORT TO GROUND
2503-FUEL INJECTOR 1 ECU INTERNAL SHORT
2503-FUEL INJECTOR 1 CIRCUIT SHORT TO GROUND
2503-FUEL INJECTOR 1 CIRCUIT SHORT TO VOLTAGE
2503-FUEL INJECTOR 1 SHORT CIRCUIT
2504-FUEL INJECTOR 2 ECU INTERNAL SHORT
2504-FUEL INJECTOR 2 CIRCUIT SHORT TO GROUND
2504-FUEL INJECTOR 2 CIRCUIT SHORT TO VOLTAGE
2504-FUEL INJECTOR 2 SHORT CIRCUIT
2505-FUEL INJECTOR 3 ECU INTERNAL SHORT
2505-FUEL INJECTOR 3 CIRCUIT SHORT TO GROUND
2505-FUEL INJECTOR 3 CIRCUIT SHORT TO VOLTAGE
2505-FUEL INJECTOR 3 SHORT CIRCUIT
2506-FUEL INJECTOR 4 ECU INTERNAL SHORT
2506-FUEL INJECTOR 4 CIRCUIT SHORT TO GROUND
2506-FUEL INJECTOR 4 CIRCUIT SHORT TO VOLTAGE
2506-FUEL INJECTOR 4 SHORT CIRCUIT
2507-FUEL INJECTOR 5 ECU INTERNAL SHORT
2507-FUEL INJECTOR 5 CIRCUIT SHORT TO GROUND
2507-FUEL INJECTOR 5 CIRCUIT SHORT TO VOLTAGE
2507-FUEL INJECTOR 5 SHORT CIRCUIT
2508-FUEL INJECTOR 6 ECU INTERNAL SHORT
2508-FUEL INJECTOR 6 CIRCUIT SHORT TO GROUND
2508-FUEL INJECTOR 6 CIRCUIT SHORT TO VOLTAGE
2508-FUEL INJECTOR 6 SHORT CIRCUIT
2510-BOOST PRESSURE REGULATOR CIRCUIT PERFORMANCE
2511-EXHAUST GAS RECIRCULATION CONTROL POSITIONER ERROR
2514-CRANKCASE VENT HEATER CONTROL CIRCUIT OPEN
2514 CRANKCASE VENT HEATER CONTROL CIRCUIT SHORTED TO OVERTEMPERATURE
2514 CRANKCASE VENT HEATER CONTROL CIRCUIT SHORTED TO GROUND
2514 CRANKCASE VENT HEATER CONTROL CIRCUIT SHORTED TO VOLTAGE
2526 - TURBOCHARGER BOOST CONTROL CIRCUIT EXCESSIVE CURRENT
2526-TURBOCHARGER BOOST CONTROL CIRCUIT HIGH
2526-TURBOCHARGER BOOST CONTROL CIRCUIT LOW
2526-TURBOCHARGER BOOST CONTROL CIRCUIT/OPEN
2527-EXHAUST GAS RECIRCULATION CONTROL OPEN CIRCUIT
2527-EXHAUST GAS RECIRCULATION CONTROL OVERTEMPERATURE
2527-EXHAUST GAS RECIRCULATION CONTROL SHORT TO GROUND
2527-EXHAUST GAS RECIRCULATION CONTROL SHORT TO VOLTAGE
2529-EGR AIRFLOW CONTROL VALVE CIRCUIT EXCESSIVE CURRENT
2529-EGR AIRFLOW CONTROL VALVE CIRCUIT OPEN
2529-EGR AIRFLOW CONTROL VALVE CIRCUIT SHORT TO GROUND
2529-EGR AIRFLOW CONTROL VALVE CIRCUIT SHORT TO VOLTAGE
2530-INTAKE SWIRL SOLENOID CIRCUIT EXCESSIVE VOLTAGE
2530-INTAKE SWIRL SOLENOID CIRCUIT OPEN
2530-INTAKE SWIRL SOLENOID CIRCUIT SHORT TO GROUND
2530-INTAKE SWIRL SOLENOID CIRCUIT SHORT TO VOLTAGE
2531-INJECTOR 1 QUANTITY CALIBRATION LOWER RANGE LIMIT
2531-INJECTOR 1 QUANTITY CALIBRATION UPPER RANGE LIMIT
2532-INJECTOR 2 QUANTITY CALIBRATION LOWER RANGE LIMIT
2532-INJECTOR 2 QUANTITY CALIBRATION UPPER RANGE LIMIT
2533-INJECTOR 3 QUANTITY CALIBRATION LOWER RANGE LIMIT
2533-INJECTOR 3 QUANTITY CALIBRATION UPPER RANGE LIMIT
2534-INJECTOR 4 QUANTITY CALIBRATION LOWER RANGE LIMIT
2534-INJECTOR 4 QUANTITY CALIBRATION UPPER RANGE LIMIT
2535-INJECTOR 5 QUANTITY CALIBRATION LOWER RANGE LIMIT
2535-INJECTOR 5 QUANTITY CALIBRATION UPPER RANGE LIMIT
2536-INJECTOR 6 QUANTITY CALIBRATION LOWER RANGE LIMIT
2536-INJECTOR 6 QUANTITY CALIBRATION UPPER RANGE LIMIT
GLOW OUTPUT STAGE DEFECTIVE
2543 INJECTOR WIRING GENERAL ERROR
2543-INJECTOR WIRING SHORTED CIRCUIT
2543 INJECTOR WIRING SHORTED TO GROUND
2543-INJECTOR WIRING SHORTED TO GROUND
2544-THROTTLE VALVE ACTUATOR GENERAL ERROR
2545-THROTTLE VALVE ACTUATOR JAMMED
2545-THROTTLE VALVE ACTUATOR LONG TERM SIGNAL DRIFT
2545-THROTTLE VALVE ACTUATOR SHORT TERM SIGNAL DRIFT
2545-THROTTLE VALVE ACTUATOR VOLTAGE TOO HIGH
2549-INJECTOR MONITORING A/D DEFECTIVE
2549-INJECTOR MONITORING VALUE ABOVE LIMIT
2549-INJECTOR MONITORING VALUE BELOW LIMIT
2549 INJECTOR MONITORING VOLTAGE TOO HIGH
2549 INJECTOR MONITORING VOLTAGE TOO LOW
2567-CYLINDER 1 LEAKAGE QUANTITY ERROR
2567-CYLINDER 1 MULTIPLE MISFIRE
2568-CYLINDER 2 LEAKAGE QUANTITY ERROR
2568-CYLINDER 2 MULTIPLE MISFIRE
2569-CYLINDER 3 LEAKAGE QUANTITY ERROR
2569-CYLINDER 3 MULTIPLE MISFIRE
2570-CYLINDER 4 LEAKAGE QUANTITY ERROR
2570-CYLINDER 4 MULTIPLE MISFIRE
2571-CYLINDER 5 LEAKAGE QUANTITY ERROR
2571-CYLINDER 5 MULTIPLE MISFIRE
2572-CYLINDER 6 LEAKAGE QUANTITY ERROR
2572-CYLINDER 6 MULTIPLE MISFIRE
2574-INJECTOR 1 MAXIMUM ACTUATION EXCEEDED
2574-INJECTOR 1 MINIMUM ACTUATION EXCEEDED
2575-INJECTOR 2 MAXIMUM ACTUATION EXCEEDED
2575-INJECTOR 2 MINIMUM ACTUATION NOT ATTAINED
2576-INJECTOR 3 MAXIMUM ACTUATION EXCEEDED
2576-INJECTOR 3 MINIMUM ACTUATION NOT ATTAINED
2577-INJECTOR 4 MAXIMUM ACTUATION EXCEEDED
2577-INJECTOR 4 MINIMUM ACTUATION NOT ATTAINED
2578-INJECTOR 5 MAXIMUM ACTUATION EXCEEDED
2578-INJECTOR 5 MINIMUM ACTUATION NOT ATTAINED
2579-INJECTOR 6 MAXIMUM ACTUATION EXCEEDED
2579-INJECTOR 6 MINIMUM ACTUATION NOT ATTAINED
2580-INJECTOR 1 ENERGY BALANCE CHARGE/DISCHARGE PLAUSIBLE CAUSE
2580-INJECTOR 1 ENERGY BALANCE TOO HIGH
2580-INJECTOR 1 ENERGY BALANCE TOO LOW
2580-INJECTOR 1 ENERGY VALUES NOT PLAUSIBLE
2581-INJECTOR 2 ENERGY BALANCE CHARGE/DISCHARGE PLAUSIBLE CAUSE
2581-INJECTOR 2 ENERGY BALANCE TOO HIGH
2581-INJECTOR 2 ENERGY BALANCE TOO LOW
2581-INJECTOR 2 ENERGY VALUES NOT PLAUSIBLE
2582-INJECTOR 3 ENERGY BALANCE CHARGE/DISCHARGE PLAUSIBLE CAUSE
2582-INJECTOR 3 ENERGY BALANCE TOO HIGH
2582-INJECTOR 3 ENERGY BALANCE TOO LOW
2582-INJECTOR 3 ENERGY VALUES NOT PLAUSIBLE
2583-INJECTOR 4 ENERGY BALANCE CHARGE/DISCHARGE PLAUSIBLE CAUSE
2583-INJECTOR 4 ENERGY BALANCE TOO HIGH
2583-INJECTOR 4 ENERGY BALANCE TOO LOW
2583-INJECTOR 4 ENERGY VALUES NOT PLAUSIBLE
2584-INJECTOR 5 ENERGY BALANCE CHARGE/DISCHARGE PLAUSIBLE CAUSE
2584-INJECTOR 5 ENERGY BALANCE TOO HIGH
2584-INJECTOR 5 ENERGY BALANCE TOO LOW
2584-INJECTOR 5 ENERGY VALUES NOT PLAUSIBLE
2585-INJECTOR 6 ENERGY BALANCE CHARGE/DISCHARGE PLAUSIBLE CAUSE
2585-INJECTOR 6 ENERGY BALANCE TOO HIGH
2585-INJECTOR 6 ENERGY BALANCE TOO LOW
2585-INJECTOR 6 ENERGY VALUES NOT PLAUSIBLE
2594-EGR AIRFLOW THROTTLE POSITION SENSOR CIRCUIT HIGH
2606-CRANKSHAFT SENSOR AND CASHAFT SENSOR MISMATCHED
2609-PRE DIESEL PARTICULATE FILTER TEMPERATURE SENSOR LOOSE
2610-CATALYTIC CONVERTER NOX REGENERATION CONVERTER THERMALLY DAMAGED
2611-CATALYTIC CONVERTER NOX REGENERATION VALUE TOO HIGH
2612-CATALYTIC CONVERTER NOX REGENERATION VALUE TOO LOW
2613-CATALYTIC CONVERTER SOX REGENERATION VALUE TOO HIGH
2614-CATALYTIC CONVERTER SULFUR CONTENT TOO HIGH
2615-CATALYTIC CONVERTER SULFUR CONTENT TOO HIGH
2621-DIESEL PARTICULATE FILTER - ASH ACCUMULATION MILEAGE EXCEEDED
2621-DIESEL PARTICULATE FILTER - ASH ACCUMULATION TOO HIGH
2621-DIESEL PARTICULATE FILTER - PLAUSIBILITY
2623 CHARGE AIR SYSTEM OFFSET DRIFT AT IDLE
2624 CHARGE AIR SYSTEM OFFSET DRIFT UNDER ENGINE LOAD
2626-DIESEL PARTICULATE FILTER - SOOT CONTENT TOO HIGH
2633 CHARGE AIR SYSTEM OFFSET DRIFT UNDER ENGINE LOAD
2641-EXHAUST GAS PRESSURE SENSOR - PLAUSIBILITY ERROR
2642-REGENERATION OF DIESEL PARTICULATE FILTER
2648-CATALYTIC CONVERTER TEMPERATURE SENSOR - PLAUSIBILITY ERROR
2649-TEMPERATURE SENSOR UPSTREAM OF DIESEL PARTICULATE FILTER - PLAUSIBILITY ERROR
2664-O2 SENSOR SIGNAL IMPLAUSIBLE
2666-O2 SENSOR FULL LOAD VALUE TOO HIGH
2666-O2 SENSOR FULL LOAD VALUE TOO LOW
2668-O2 SENSOR OVERLOAD VALUE TOO HIGH
2668-O2 SENSOR OVERLOAD VALUE TOO LOW
