window washer relay
Welcome to DF
Sorry i was out of town.
REMOVAL
WARNING: To avoid personal injury or death, on vehicles equipped with airbags, disable the supplemental restraint system before attempting any steering wheel, steering column, airbag, seat belt tensioner, or instrument panel component diagnosis or service. Disconnect and isolate the battery negative (ground) cable, then wait two minutes for the system capacitor to discharge before performing further diagnosis or service. This is the only sure way to disable the supplemental restraint system. Failure to take the proper precautions could result in accidental airbag deployment.
Disconnect and isolate the battery negative cable.
Remove the fuse access panel from the steering column opening cover below the steering column on the instrument panel.
Reach through and below the outboard side of the fuse access opening to access the wiper relay (Wiper Relay Remove/Install).
Remove the wiper relay by grasping it firmly, releasing the latches and pulling it straight down from the receptacle on the bottom of the fuse block.
REMOVAL
