Dodge Sprinter The Dodge Sprinter is all function, with styling cues from the Dodge Truck line, it makes the workaholic's job much easier. Check out the Dodge Sprinter in showrooms today!
starting problem
Old Dec 11, 2011 | 09:09 PM
bluenose51's Avatar
bluenose51
Default starting problem
Hi 2 every one, just joined Dodge form.can any one help i have a problem with my battery.I think,when i turned the engine of i heard as if a fan was still running,later on i went to turn the engine back on and my battery was dead,can some one advise please.thank you.
Old Dec 11, 2011 | 09:12 PM
bluenose51's Avatar
bluenose51
sorry i forgot its a mercedes sprinter 416 cdi 2.7cc
Old Dec 11, 2011 | 11:17 PM
master tech's Avatar
master tech
Site Moderator & Tech
You may have a relay causing the fan to stay on. Find the relay and pull it out. see if the fan is off and then recharge the battery. Then check to see if the engine will start.
Old Dec 12, 2011 | 07:13 AM
bluenose51's Avatar
bluenose51
Thank you i will have a search for the relays to day.
