Dodge Sprinter The Dodge Sprinter is all function, with styling cues from the Dodge Truck line, it makes the workaholic's job much easier. Check out the Dodge Sprinter in showrooms today!
Sprinter trans rebuild
Old Jan 9, 2012 | 10:35 AM
A.TX.Mopar's Avatar
A.TX.Mopar
Default Sprinter trans rebuild
I just finished rebuilding a transmission for an '05 Sprinter and am now running into problems that I believe lie in the valve body. The 2-3 overlap regulator valve doesn't seem to want to move properly. The valve itself looks fine, no burs or scratches. Same with the valve body. Everything is torqued down right but when the truck shifts into 3rd the trans shuts down and the wheels nearly lock up. Voltage is correct in all the right places and there are no more transmission codes. Did taking the valve body off/apart warp it? Any help would be great.
Old Jan 9, 2012 | 10:11 PM
master tech's Avatar
master tech
Site Moderator & Tech
The problem maybe the valve body itself. I have had sticking valve before.
Old Jul 7, 2012 | 11:55 AM
ALASKAPF-185's Avatar
ALASKAPF-185
Ever find out why or what the solution was. Updates are always helpful to point others in the correct direction. Thanks
Old Jul 8, 2012 | 11:07 AM
A.TX.Mopar's Avatar
A.TX.Mopar
I can't remember exactly which one but one of the clutch pack retaining rings had broken. If you try to rebuild one of these things buy new rings.
Old Jul 8, 2012 | 03:10 PM
ALASKAPF-185
Thanks for the update, any idea on what the average life is on these NAG1's in the sprinter cargo vans. With proper maintenance and not overloading.
