Dodge Sprinter The Dodge Sprinter is all function, with styling cues from the Dodge Truck line, it makes the workaholic's job much easier. Check out the Dodge Sprinter in showrooms today!
trans problems/shifter
Old Nov 14, 2006 | 06:08 PM
shagybruce's Avatar
shagybruce
Default trans problems/shifter
anyone out there experienced these problems with the sprinter? after starting the vehicle the gear shifter stays locked in park. have to manually unlock and then i only get 1 forward and reverse gears. wait about 5 mins then i get all the gears. while driving for a while stays in drive. will not kick down and you cant manually d- or d+ even after stopping then losing the gear selection display in the console completely. dealer has replaced the brake swith and the shifter assy $700!!!!! any info would be appreciated.
Old Mar 11, 2007 | 11:44 PM
shagybruce's Avatar
shagybruce
Default RE: trans problems/shifter
update...three shifters and two brake light switches later and also a ton of time tracing wires looks like the problem was in the abs modulator....replaced, all working ok touch wood....fyi only code given was no signal to shifter....
Old Mar 16, 2007 | 09:30 PM
shagybruce's Avatar
shagybruce
lasted a week now back to square one....dealer has no idea how to fix it and i'm tired of them throwing parts and my money at this thing..anyone have any ideas??? dealer has called my van possesed...is the trans electronially controlled..and if so does it have its own ecm?? pulling at straws here..
Old Mar 26, 2007 | 06:46 PM
4ADAM 12's Avatar
4ADAM 12
There is a Transmission control module, it's located under you're driver seat. Slide you're drivers seat as far forward as possible this should give you access. There is also a cover on the side of the seat pedistal, but I believe this only gives you access to fueses.
Old Mar 27, 2007 | 09:32 PM
shagybruce's Avatar
shagybruce
dropped it off friday picked it back up yesterday...seems to be o.k. at the moment thing is they didnt tell me what they did..said just "try it" it was free so we'll see i guess..
Old Nov 16, 2007 | 03:56 AM
vpracegasatlanta's Avatar
vpracegasatlanta
Have you bumped into anything recently? I bumped the car in front of me and that set some sensor off where the same thing you are talking about happened. My Sprinter dealer had to reset something that fixed it.
