Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
18 spline to a 25 spline?
Old Apr 3, 2007 | 03:40 PM
92stealth's Avatar
92stealth
Default 18 spline to a 25 spline?
lol there are alot of people online right now.
ok back to the topic. in my 91 stealth i need to change tranys in, but i think its a 18 spline (made in june or july of 91, my parts car is a 92 made in march so its most likly a 25 spline.
so say my parts car is a 25 and the 91 is a 18 what do i need to take out of the parts car to make it work? do i only need the trany and the transfercase from the parts car to make the 25 spline work with my 91?
lol sorry for all the numbers
Old Apr 7, 2007 | 01:39 PM
92stealth's Avatar
92stealth
Default RE: 18 spline to a 25 spline?
anyone?
Old Apr 7, 2007 | 05:25 PM
yevgenievich's Avatar
yevgenievich
sorry, but i have no idea of differences, and seems like nobody else does. i would try 3si.org
Old Apr 7, 2007 | 07:00 PM
92stealth's Avatar
92stealth
i did try there and thats where i came up with this question.
im not going to post it on there, since most of the time they will just flame.
Old Apr 8, 2007 | 12:53 PM
thestealth's Avatar
thestealth
I agree about the people who flame on 3si...but use the forum search feature (not the Google one) and you should be able to find some threads on this subject.
I know you will need the tranny and transfer case and possible the cv axles/halfshafts. I think the driveshaft is the same.
Old Apr 8, 2007 | 05:41 PM
92stealth's Avatar
92stealth
ok thanks.
i used the search thing on there and saw the old threads, and i still came up with this question since its not to clear to me.
i find this place to be more friendly so i just wanted to see what people would say...
Old Apr 9, 2007 | 12:26 PM
92stealth's Avatar
92stealth
i searched again and this is what i got.
my question is, all the stuff that is listed that i need, is that stuff all attached to the trany and tc already? if not were is it located?
The parts that will need to be swapped out include the 25 spline output shaft, output shaft seal, TC input spool, sun gear, VCU, pinion shaft, and transaxle bell housing. If you have an 18 spline TC with out the bolt near the center of the “Getrag†cover, then the front TC housing, passenger side bearing and input gear will also need to be swapped out along with the TC spool as one of the bearing bores in the housing is a larger diameter for the 25 spline spool and the hole in the gear for the spool is also larger in diameter. (More info is bellow on TC housings/spools.)
Old Apr 9, 2007 | 02:21 PM
thestealth's Avatar
thestealth
Those are the internal parts that need swapped. In your case, since you already have a donor car, it would be easier to swap out everything.
Old Jan 20, 2025 | 11:44 PM
hunterceg's Avatar
hunterceg
Default I think all you have to change is an intermediate shaft and the 2/2 shafts that shoul
Just change the intermediate shaft and the 2 1/2 shafts and you should be fine]
Old Jan 21, 2025 | 06:11 AM
Moparite's Avatar
Moparite
18 year old thread!
