Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
Check engine light-Stealth
Old Sep 8, 2004 | 11:44 PM
preludesh01201's Avatar
preludesh01201
Default Check engine light-Stealth
I have a stealth front wheel, and i got a Check engine light. I want to see if its similar to my honda and how to reset it. Is there any way to reset it and how can i check what the code is? Any trick and any site besides a helm to find out the codes. I appreciate your help!!!!
Old Sep 9, 2004 | 03:58 PM
thestealth's Avatar
thestealth
Default RE: Check engine light-Stealth
Not sure if it is the check engine light or the SRS (airbag) light that must be reset at the dealer. You might want to check 3si.org/forum or us3s.com/freeforum for more info. You may be able to reset it by unhooking your neg(-) battery cable for 10 minutes. That reboots the ECU and may clear the CEL. I am not 100% positive it will clear the CEL though.
http://www.us3s.com/freeforum/showthread.php?t=3292
Here is a thread that tells how you can check the error codes yourself if you have access to an analog volt/ohm meter or make one with Radio Shack parts.
