Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
single turbo and 3.5 heads
Old May 12, 2007 | 01:20 AM
csladek11's Avatar
csladek11
Default single turbo and 3.5 heads
i have a 92 stealth es dohc. Iwas woundering if I could put 3.5L heads from a montero on to my car. I would rebuild them and im pretty sure they would bolt up or would they? Also I was thinking of custom fitting a single turbo to my y pipe instead of my manifolds to get equal flow but I was wondering if it would be to hard to do or would tear up my motor. I won't use much boost only like 10 to 15 pounds. I dont want to spend much money on it all thats why im not doing a whole tt conversion but i just want some extra power. Any info on any of this?
Old May 12, 2007 | 02:31 AM
EvilZombieZ's Avatar
EvilZombieZ
Default RE: single turbo and 3.5 heads
I wouldnt try to rig up some custom turbo setup, I would just do it the right way so you dont end up breaking something, and the 3.5l heads shouldnt fit in your 3.0l stealth, but you should wait till thestealth comes on to clearify.
Old May 12, 2007 | 02:33 AM
yevgenievich's Avatar
yevgenievich
i was looking at one turbo setups before and i was able to find all the parts at about $1000. I'm not sure how much tt convertion costs but one turbo is an option(just not common).I wouldn't think that 3.5L heads from montero would fit. Personaly i think 10-15 psi is a lot of boost, when i was thinking to do mine i was going to set it at 5 psi(my stealth have a lot of miles)
Old May 12, 2007 | 03:33 AM
EvilZombieZ
10-15 psi is quiet a lot of boot for a car, little would in my opinion be 5 or less. but the block probably cant fit 3.5l heads or anything.
Old May 12, 2007 | 03:26 PM
92stealth's Avatar
92stealth
10-15 is ALOT if you look at the stock TT's, they run 12 i think.
Old May 12, 2007 | 07:35 PM
thestealth's Avatar
thestealth
I've never seen a side by side comparison of the heads, so I don't have any idea if they would bolt up or not. There is really nothing wrong with the stock heads, especially if you have a reputable shop port and polish them.
You won't be able to run that much boost (for very long anyway) on stock internals. 5 to 8 lbs is about all you want to run on 10:1 compression. If you want to run more boost, you'll need to upgrade your fuel system, engine/fuel management, engine internals and you'll need a datalogger et. al. It's not so easy as just slapping on a turbo.
Old May 12, 2007 | 07:45 PM
EvilZombieZ
Hell if it was that easy id have 8 turbos, and nobody say its not possible cause there is a car with8 turbos.
Old May 12, 2007 | 07:58 PM
thestealth's Avatar
thestealth
Yeah, it's a 57 Chevy or something isn't it?
Edit, it is a 57.
Old May 13, 2007 | 01:48 AM
yevgenievich
now, why in the world would you want 8 turbos??? I did seen double supercharged gto tho, those superchargers were sticking up higher than the car it self. But eight turbos....
I wold think that after you get twin turbos the effectivness of next ones goes down to almost nothing.
Old May 13, 2007 | 01:53 AM
EvilZombieZ
yeah ive seen a double supercharger gto too, but could you imagine the speed 8 turbos give you... I mean if they did nothing im sure he wouldnt of done it.
