Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
HELP
Old Jul 12, 2007 | 09:44 PM
Maxcheco89's Avatar
Maxcheco89
Default HELP
the oil guage on my 95 stealth es is reading below the L so im guessin there is no oil pressure but im not hearing any of the valves tapping at all n my oil light doesnt even go on and i drove it and it ran like nothin is wrong what should i do?
Old Jul 12, 2007 | 09:53 PM
thestealth's Avatar
thestealth
Default RE: HELP
The sending unit is on the driver side, behind the plastic fenderwell. I think you can reach it by turning the wheel all the way to the right and reaching through the gap. The wire could have came off, the sending or gauge went bad, or you could not have any oil pressure.
Old Jul 12, 2007 | 10:15 PM
Maxcheco89's Avatar
Maxcheco89
Default RE: HELP
ok thanks ill check that out also something i forgot to mention while i was driving the oil pressure gauge was going up ann down while i pressed the gas n my RPM's went up the gauge went up and when i took my foot off the gas and i let my RPM's drop the oil pressure dropped too then i took my eyes off it while i was driving then when i looked at it the oil pressure gauge didnt move for nothing like it went dead or something
Old Jul 13, 2007 | 09:18 AM
thestealth's Avatar
thestealth
Default RE: HELP
Sounds like a loose connection...but to be sure, you might want to pick up a cheap mechanical guage to hook up in the engine bay just to make sure you are getting oil pressure.
Old Jul 13, 2007 | 01:37 PM
Maxcheco89's Avatar
Maxcheco89
Default RE: HELP
ok thanks
