help with spark plugs
Unhook the intake pipe from the throttle body, unhook the speedo cable, unbolt the 3 plug harness on the intake, remove the 9 (I think) nuts/bolts on the intake, use a bungy cord to hold the intake up towards the hood, remove plugs. There are 2 hidden nuts on the back of the intake manifold. Once the intake is removed, cover the lower intake tract so you don't drop anything into the cylinders. It is easiest to get to the plugs from the drivers side. It's a pretty easy job once you do it a couple of times.
