Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
Needing turbo
Old Oct 9, 2007 | 10:11 AM
thestealth's Avatar
thestealth
Default RE: Needing turbo
The most economical way is to find a TT (or VR4) donor car. You can also buy a jdm front clip that has all the parts you need. There are really no "bolt on" options, unless you plan on buying headers, turbos, oil cooler/lines, intake, intercoolers and required plumbing, oil pan, front engine mount, engine management, wiring harness (not totally necessary, but a good idea). Add all those up, and it would likely be cheaper just to buy a TT...
Old Oct 9, 2007 | 11:53 AM
skate_or_die2008's Avatar
skate_or_die2008
Ok i have another question ... if i found a tt motor .. what all would i have to do the swap? ...
Old Oct 9, 2007 | 12:44 PM
thestealth's Avatar
thestealth
http://www.deftracing.com/tt.htm Here is a checklist of what you will need.
Old Oct 10, 2007 | 12:30 PM
skate_or_die2008
thanks illl look into it
