Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
valve adjustment
Old Oct 25, 2007 | 12:59 PM
thestealth's Avatar
thestealth
Default RE: valve adjustment
ORIGINAL: jookie7705
However, if I'm not mistaken, I don't think there is a "valve adjustment" procedure on the 3S.
You are correct, there is not a valve or rocker arm/lifter adjustment on these engines.
Generally, the noise you are hearing is lifter tick (as rod knock is generally pretty pronounced and noticable).
From the service manual, slowly rev the engine (in neutral) to 3000 rpms, then slowly allow the engine to come back to idle speed. You may have to repeat the process a couple times. Usually, this will prime all the lifters (lash adjusters) and the ticking will subside.
There is a spring on the clutch pedal, the clutch itself is hydralically operated.
Old Oct 27, 2007 | 11:02 AM
sickstealth1's Avatar
sickstealth1
if i pin point what lifter it is can i only change out that whats needed or do i have to do all of them?what type of oil should i use in this car it has 120,000 . synthetic or light /heavy motor oil? thanks
Old Oct 27, 2007 | 11:47 AM
jookie7705's Avatar
jookie7705
Well, yes... you could do one. But since you'd already be in there, you might as well do them all. Besides, if you do only one, you won't be getting the benefit of the 3rd gen lifters. You'd have one that has the 3mm opening while the others still have 1mm.
Here's more info:
http://www.geocities.com/t115_2000/Adjusters.html
http://www.stealth316.com/misc/insta...ew_lifters.doc
Old Oct 29, 2007 | 11:57 AM
yevgenievich's Avatar
yevgenievich
ORIGINAL: sickstealth1
if convential oil been used before then stay with conventional. 10w-30 should work
if the motor had synthetic in it all it's life then could use 10w-30 synthetic
