Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
clutch
Old Mar 28, 2005 | 09:25 AM
casper's Avatar
casper
Default RE: same prob dude!!!
Sounds like a bad master or clutch to me. More information about the problem would help a little.
Old May 24, 2006 | 04:01 PM
satanicmechanic's Avatar
satanicmechanic
I have a similar problem and i plan to bleed the slave cylinder first and see if that helps and if it doesnt i will replace it. Because my clutch pulls great but only the last part of the pedal play gives me the in and out of the clutch which kills my leg and foot reachign all the way down there...
Old Jun 1, 2006 | 05:39 PM
falcon66's Avatar
falcon66
My 91 ES just started doing something similar. Every once in a while the clutch pedal seems to stick down, not fully dis-engaging. I put my foot under it and popped it back up and it seems to work OK for a while. It seems to occur after driving for 15 minutes or more. The clutch fluid level looks OK and I doubt the clutch is going due to the intermittant symptoms. What did you guys find?
Old Jun 2, 2006 | 04:07 PM
satanicmechanic
I did the clutch pedal freeplay adjustment and it works great now. Took a bit to figure out since im still waiting on my manual to make it through the mail. Its EASY though once ya figure out whats going on and how to adjust it. IT made all the difference in the world on my clutch leg. Though that is STILL the stiffest clutch i have EVER used.
Old Jun 16, 2006 | 02:57 PM
falcon66's Avatar
falcon66
I finally found my clutch slave cylinder is leaking allowing air into the end of the system. Apparently this prevented my clutch from fully disengaging causing the 'automatic tranny like' symptom and difficulty getting into gear. It also helps to pull the cap off of the clutch master cylinder to check level instead of looking through the translucent housing (darn ring around the collar!).
