Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
starting problem!!!
Old Dec 16, 2007 | 07:15 PM
JokerzVeng's Avatar
JokerzVeng
Default starting problem!!!
hey whats up all...having a problem with my 92 stealth 3.0 SOHC NA auto.
ok the problem is i was driving home from work the a couple weeks ago...stopped by the store to get some beer..and when i came back out to start her she wouldnt crank..changed out battery..nothing..checked for power to main battery side of the starter...it has power...checked ignition side of starter as helper turns key to start...has power..so i buy a new starter..install the starter..stilll nothing..no noise from the starter or solenoid..the only thing i can hear is what is prolly my fuel pump making noise as i try to start it not sure bout this though only makes noise when i have the key in start position...plz help a fellow wopar man out will ya...
Old Dec 17, 2007 | 09:52 AM
jdl's Avatar
jdl
Default RE: starting problem!!!
Is the starter putting a load on the circuit? If you turn on the headlites, how do the lites react, when you turn the key to start? If they stay bright, no reaction, there is an open circuit for your starter somewhere. Could be on the positive or ground side of the starter circuit. Your saying the starter and solenoid are new, correct?
Is there a field circuit, that goes from the solenoid into the starter body, that circuit should be hot, with the key turned to crank. If it isn't, you need to backtrack your testing.
