Wiring
Wiring
Okay so i took my car in the other day to wash it. Before nothing was wrong but now my speedometer, tach, gauges, parking lights, and taillights all dont light up. I know the wire is grounding out. I am really not looking forward to tearing my car apart trying to find this frayed wire. So i was wondering if anyone here knew where is should start looking, or if you should bite the bullet and take it in to let a professional handle it. [:@]
Thanks
Thanks
RE: Wiring
Like blink said, start checking fuses first. Under the hood on the passenger side in front of the air-box is a fuse box. Under the dash above where the clutch pedal would be is another fuse box. Other than that, chasing electrical gremlins is mostly a trial and error affair. A real PITA. Good luck.
RE: Wiring
More than likely it is a ground wire. There are 5 or 6 in various places throughout the car. Offhand I do not know where they are. I will have to check the manual to find out for sure. If you can wait another day, I'll find out where they are.
In the meantime, search through this site, stealth316.com. I am sure somewhere on his 200 page site will be grounding locations.
